reloaded my info. 12.2%
You pushed disagree because of a typo????
@Dave46 What is your new maximum kW power output at "100%"
I'm not sure to what you referring. FWIW, I did check the reported distance today — at 85% it's showing a range of 189 miles, which would calculate to ~222 miles full charge; I also rechecked the full-charge capacity while supercharging today (which again was capped at 60 kW, though it could be a faulty supercharger — one of the plugs was out of order), and it's now down to ~66.75 kWh… but my rate of charge doesn't drop off nearly as quickly as it used to — I was still pulling in 58 kW at 80%.Did not mean switching between % and miles on your display. Meant the % you have charge to, on the charging app screen where you set your charge % limit.
Allow me to lump myself in…
2012 Model S Signature Edition — original 85 kWh pack w/~65k miles on it, went from ~76 kWH full charge as recently as a couple months ago to ~71 kWH a couple weeks ago. Just as troubling for me, if not moreso: whereas previously I could charge upwards of ~95% and still have full regen, now I start losing regen somewhere in the low-to-mid-80s — haven't quite narrowed it down yet.
Also potentially worth noting: I started seeing 60 kW max supercharging within the last month or so, though that spontaneously went away within the last week.
I had a little — it was around 77-78 kWh when I first got the car not-quite-2 years ago with a little under 43k miles on it, and was around 75-76 kWh (75.8 if memory serves) when last I checked sometime in April after having put on another 22k miles; that it dropped to 71.2 within the span of a month and a half, then to 66.75 another 2 weeks later (who knows how much further it has yet to go) is neither perfect nor fine, but at least there's some semblance of a rationale behind it.Sorry but that is just not possible.
That basically means your old values would state that you had NO degradation. On a 2012 car
71kwh is perfectly fine.
Good point — it is an original battery pack (limited to 90 kW supercharging and all), but the original battery pack? They told me it hadn't been replaced, but who knows… I certainly don't know how to check the battery pack's odometer — I presume there's special equipment and/or a service (which requires my Tesla credentials) that could read that?The battery had probably been replaced. What is odometer on the battery?
Interestingly, after not being able to charge beyond 97% three times, last night I reached 100%. I did not experience the same 2kW or so slow charging beyond 95%.
Note the pack and cell voltages below. The data is from a few minutes after completing the charge. The pack also seems to have gained a kWh or so from a few days ago.
After supercharging or home charging?
@2019.20.1.1?
My car stalled at 1kW and 96% last monday, like yours. After updating to 2019.20.1 (from the ominous 2019.16.2) my car exactly replicated your most recent behaviour. Supercharging to 99% now yields 328 km.Interestingly, after not being able to charge beyond 97% three times, last night I reached 100%. I did not experience the same 2kW or so slow charging beyond 95%.
I just installed 2019.20.2.1 and SC this morning to 90%My car stalled at 1kW and 96% last monday, like yours. After updating to 2019.20.1 (from the ominous 2019.16.2) my car exactly replicated your most recent behaviour. Supercharging to 99% now yields 328 km.
Supercharging, 2019.20.2.1
I had my pack replaced and the pack odo matches the vehicle odo.
It was immediate for me also. Which is why it was a concern when I noticed 3 miles degradation, then 10 miles on the following charge.Correct me if I'm wrong, but it can take a few thousand miles to see most of the drop after the software update, right?
Sounds similar to my experience. Prior to 2019.16.x firmware, I was getting throttled Supercharging. Then it appears 16.x opened that back up when I think they bumped up the Supercharging rates to 150kW. Now it appears it has stepped down again after 20.x. My SoC wasn't as low as I liked and I was having problems with it displaying properly on my screens so that could have affected what I was seeing. Will know next time I SC with lower SoC.I just installed 2019.20.2.1 and SC this morning to 90%
I got no added range back (didn't expect it)
I did see limited initial charge current. I used to get 105kW or so, today it went to about 85kW before settling at 74kW
Dropbox - 20190626_071958.mp4 - Simplify your life
