Sudden Loss Of Range With 2019.16.x Software
Discussion in 'Model S: Battery & Charging' started by Dutchmeeuw, Jun 3, 2019.
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. fbitz777
    fbitz777 Member
    Wexford, PA
  2. sdoorex
    sdoorex Member
    Front Range, CO
    Then what changed? You've been very adamant against disclosing anything publicly so why the change of heart?
    • Disagree x 1
  3. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    #14263 wk057, Feb 12, 2021
    Will save the details for my writeup. But long story short, since the issue is now mitigated in a satisfactory manner, I see no reason to keep the information private any further.
    Anyone affected by "Condition X" will have a replacement battery by now (I know of none, but such cars would have shutdown and locked out the battery long ago on any firmware version as far back as 2012).
    Anyone affected by "Condition Z" who's actually been installing updates in a timely manner should no longer be affected by "Condition Z" by now, or will very soon no longer be affected (algorithms at work). Any range loss will be normal degradation at this point. (I've seen quite a few posts and other data that confirms this.) Edit: You do also have to actually use your vehicle about an average amount or more for this algorithm to get enough data to implement mitigations.
    If you've been an update holdout... well, you're a bit SOL. Even if you update now, it'll take a significant amount of time to calibrate and mitigate (many months).
    Again, no safety issue, no fire issue. It's really not that impressive.
    (Also, thanks to whatever mod is actually approving my posts here.)
    • Informative x 17
    • Like x 5
    • Disagree x 1
  4. Droschke
    Droschke Active Member
    Future
    20+ miles loss of range overnight, with none of it has been restored to this date, is not normal degradation.
  5. wk057
    Hickory, NC, USA
    #14265 wk057, Feb 12, 2021
    You also have to actually use the vehicle for the mitigation to complete. It appears to take 20-30 cycles (sum of fractional cycles, not necessarily full 0-100-0) after it starts gathering data, which would be 4-8k miles, depending on standard YMMV factors.
    If the 2015-02 delivery and 46k odo stat in your signature are correct, my guess is the ~640 miles/mo avg you do hasn't quite allowed the algorithm to complete yet. (I believe it's been gathering required data since 2020.30-something.) Either that, or it has and you have an unrelated problem. More likely the former.
    • Informative x 8
    • Disagree x 1
  6. Smiles83
    Smiles83 Member
    Edmonton
    Thanks for the updated info u have found and posted. However why are the supercharging speeds still 1/2 of what we were getting before 2019.16 if these issues have been mitigated?
  7. fbitz777
    fbitz777 Member
    Wexford, PA
    So is voltage "slowly coming back" to 4.2V at 100% SOC? Even normal degradation would show 4.2V not the 4.1V or around we see in this forum. I know My X75D takes in REGEN (assuming warm weather) at 100% "SOC (I.e the old 90%) so obviously I have been voltage capped.
    • Helpful x 2
  8. wk057
    Hickory, NC, USA
    Supercharging speed issue is mostly unrelated. There can be some slowdown during the runup to mitigation and pre-mitigation (will explain in my writeup), but afterwards this issue is unrelated.
    Supercharging stuff is mostly related to calendar life related functions in the BMS. Honestly, that stuff seems pretty shady to me, but it is unrelated to the range loss stuff.
    Depends on your pack, the exact calibrations, and a bunch of other factors. If you were affected by condition Z, you'll have lost a few miles of range to the mitigation implementation in a worst case scenario.
    Again, will note details in my writeup, probably Sunday. So keep an eye out for that.
    Still on moderation here, but at least the traffic in this thread is low enough right now that my posts aren't getting insta-buried. I doubt that will be the case after my writeup.
    • Informative x 5
  9. Gwgan
    Gwgan Almost a wagon
    Maine
    Is there a specific software version where mitigation happens or just once enough information has been gathered? I have accumulated about 5k miles since 20.32 but am stuck on 20.48.12.1.
    Looking forward to the full report.
  10. Jkr85
    Jkr85 Active Member
    Rotterdam, The Netherlands
    Bummer! 85D here, holding back on updates since 2020.8.2 because of worsening AP1 (EU legislation induced). now I have to figure out what the abbr. SOL means. Sigh.
  11. Jkr85
    Jkr85 Active Member
    Kudo’s to @Gwgan for explaining the meaning of and expletive in SOL via DM. Still shocked. @wk057 needs to be careful here... mods are reading ;)
  12. oaito
    oaito Member
    Europe
    Took me some time to understand "SOL", still not 100% sure... at least I'm not the only one:
    :D
    @wk057
    Firstly, I am looking very much forward to a writeup regarding the different possible / actual battery conditions and the mitigation by the BMS! AFAIK from reading your earlier posts in this thread and what I could find in other threads through the search, please correct me if I'm wrong: So far I understood, you are primarily referring to the capacity reduction by reducing the max brick voltage by the BMS. It would be greatly appreciated by myself and I am guessing most of the fellow drivers here, to hear what you can tell us about the reduced charging rates and if these ever will be restored to levels equally to the charging rates at e.g. 2019.12.1.1?
    Thanks a million and looking forward to your next insights! Oaito.
  13. wk057
    Hickory, NC, USA
    • Funny x 2
  14. JRP3
    JRP3 Hyperactive Member
    Central New York
    He addressed that:
  15. oaito
    oaito Member
    Europe
    ...thanks for quoting, this is exactly why I was asking and subsequently hoping wk057 could provide more regarding "calendar life" and "shady". IMHO these two sentences are actually more a teaser...
    BR! Oaito.
  16. PeterMcDade
    PeterMcDade New Member
    San Diego
    2013 S P85+ CPO UNTIL MAY 2021 - Believe battery issues started nearly two years ago, at first increased range with ongoing extended noise under car after charging, and now quick loss of charging and "miles." Found this listing and ask following:
    1) Is there a member name, a date, or, key page - that I can go to and read a summary of what the current actions are that I should take with Tesla before my time on CPO warranty runs out?
    2) Suggestions on the best app, OBD-II adapter and BT interface that download/purchase to track what is and is not going on with my S?
    Thanks in advance!
  17. Krash
    Krash Data Technician
    Intermountain US
    Do you mean connector in the second case? Hard to beat ODBLink MX+ for the third. Do you use iOS or Android?
  18. PeterMcDade
    San Diego
    From my reading, I just ordered the connector/adapter cable from GPS Tracing America. Are you recommending the MX+ OBDLink for the Bluetooth adapter?
    I use Android phone, and, also have Macbook Pro computer - which is better to use?
  19. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    Extremely looking forward to this!
    • Like x 4
  20. raphy3
    raphy3 Member
    Elsewhere
    Ok that's interesting to know. I think we need that mod (automotive not forum mods...) you mentioned a while back: a switch that allows us to turn off this SuC limit for the once in a while we need really fast charging.
    It seems that SuC limiting began in various forms before batterygate, but many people here got hit with a chargegate hammer about the same time that Tesla decided to cap batteries too. For my part my charging was gimped by more than 50% speed after Tesla forced an update to replace it's badly designed door handles.
Thread Status:
