Bjorn talks about his Model 3's battery reduced supercharging:
I agree with pretty much everything stated here.
If you research Power Wall type products - pure battery storage appliances - they typically have quite strict and clear warranty terms. When making my selection of storage battery, I preferred a clear cut warranty of the amount of energy passing through the battery. It's the energy that has value, and while how fast the energy can be added to or removed from the battery clearly makes a difference, I'm prepared to work around such limitations in order to fit in with what the battery prefers to give longest life. The longer the battery can continue processing energy usefully, the higher its value becomes.
We need to have a different view of our EVs to how we saw ICE vehicles. The battery has a predetermined life expectancy during which it can process a certain amount of energy while still meeting the needs of the application. The warranty should underwrite a large portion of that period. Outside of the expected reasonable performance, it's like free money the longer you keep your battery doing a useful job. You bought it knowing it had an anticipated life cycle, so the longer you can prolong that, the better off you are.
Elon keeps restating that slow charging is preferable for longevity, and he's right. Same as Bjorn points out. Battery care is something that every EV owner should take into account because it benefits them if they keep the car longterm, and whenever they sell it will benefit the next owner and the planet.
Bjorn makes an interesting point that's obvious but only recently become very clear to me. A higher capacity battery is not just about range. It can also process larger amounts of energy and be operated well within its 'comfort zone' for more of its life (especially by obviating DCFC).
It is a verifiable fact that stems from the physics / chemistry of the batteries that they have a known deterioration pattern that is exacerbated by certain use parameters - fast charge, fast discharge, use outside optimal temperature range, prolonged storage at full charge levels. No way around this stuff except to take them all into account and give your battery the most sympathetic use possible without making your car unenjoyable or impractical. That balance will be different for each owner, but I personally enjoy having and carefully using nice things and looking after them to maximise my enjoyment.
