Cell brick problem?! Your guess means there's a problem over Tesla diagnostic? You're worrying too much about it. Just follow the manual and plug in whenever you can and charge to 80-90%.
Thanks Tim. Very informative. On my previous 3 I was charging regularly to 90%. The day I let my charge go down to 60% and charged back up to 90% I lost 10 miles and never got them back. I don’t have the Teslafi range chart anymore as I picked up my new 3 yesterday. Details in my signature.I saw this in another post here, about balancing the cell bricks to each other. I'll try keeping the car plugged in with a charge limit at 90% for a couple weeks straight and see if that helps.
Copied text:
Incorrect-- brick balancing occurs independent of the car being plugged in. It occurs based on SOC above ~85%. Here's the section from the Model 3 Service Manual with the key sentence in bold:
Brick Balancing
Note that the capacity of a pack is limited by the brick with the lowest capacity. When that brick is charging, it will gain voltage faster than other bricks. The HVBMS will stop charge when any brick reaches its ceiling voltage (~4.2V). If one brick has a significantly lower capacity that others, the pack will be limited by that brick which will get to 4.2V faster than the other ones. We refer to the brick with the lowest capacity as: min CAC. In periscope, its value can be seen by viewing the signal: 'BMS_cacMin'
Another limitation could come from bricks being imbalanced, or some bricks with a voltage higher/lower than others. This would limit ability to charge the pack as the brick with a higher voltage than others would reach the ceiling voltage early. Same idea when discharging, the brick with the lowest voltage would hit the floor voltage early which would cause the HVBMS to open contactors from low power
To mitigate this imbalance, Batman has some bleed resistor that can be placed and removed in parallel of each brick via a FET relay. Batman can put that resistor across the brick with the highest voltage which would slightly discharge that brick and bring it back to the level of the other bricks. Batman closes a FET which puts that resistor across the brick. The HVBMS will order Batman to put that bleed resistor across the brick with the highest voltage when Delta V is > 5mv MinBrickV > 4.0v (~85% SOC) && HVBMS State == STAND BY.
Note that Batman can also do balancing when the HVBMS is asleep.
The best way to balance the Model 3 pack is to set charge limit to 90% or higher and let the vehicle sit idle for hours (plugged in or not). 24 hours of balancing can reduce imbalance by 1mV.
Same thing happen to my 2018 July, LR model 3 with 32000 miles. It has always been around 278-279 mile range at 90% charge and 309-312 at 100%. Then one day sometime last month it happed! Now 264-265 at 90% charge consistently. That’s over 5% degration all of a sudden, not gradual but just boom! One day normal, next day dropped 5%.
Sigh, seems like every generation of owners goes through same cycle:
It's a real concern to many of us. I have lost 9% of battery. Measured with an OBD2 cable. Now at 70.5 kWh from 77.8 kWh in 17500kms (less than 11000 miles).
It's 77.8 including the buffer. The Full Nominal Pack of new cars are around 77 ~ 79, confirmed at the Service Center. One of the guys checked a new car using his tools and it had 78 kWh.But a Model 3 only starts with ~74.5 kWh, not 77.8 kWh... So you are closer to 5% degradation.
try to trickle charge, our home charging spot has been inaccessible for about 3 weeks now and ive been trickle charging on 12v and my 90% has gone from 264 to 270.
I've tried all sort of different techniques... It's a "problem" on some batteries. I'm sure Tesla knows what's going on there. It's not up to the user. The user did not do anything wrong. They just had bad luck when purchased the car.
It's the TESLA BATTERY LOTTERY. If you got a decent one you should be happy. Some of us got one of the worse quality batteries but Tesla guarantee is very clear... So we can loose up to 93 miles and still have a battery that is "normal".
I have the same problem. 7/2018 Model 3 LR RWD 20000 miles. At early 2018, the mileage range was pumped up from 310 to 320 by a software update. Then it started to drop about 0.5-1% every month. Right now it's 288 miles for 100%, or 259 miles for 90%. I have contacted the service several times and each time they said the battery is fine and told me different ways how to bring the range up by charge the battery to 90% everyday for 4 weeks, discharge it to low % then charge it to high %... I followed and nothing change except 0.5-1% drop every month. Today, I requested a real battery diagnosis at a service center, they rejected and said they can't do nothing until my battery degraded more than 30%. It's the TESLA BATTERY LOTTERY! How can we bad luck people do?
