Suggested Supercharger Locations
Discussion in 'Supercharging & Charging Infrastructure' started by daxz, Apr 1, 2012.
  1. daxz
    daxz Member
    Denver, CO
    #1 daxz, Apr 1, 2012
    The last TM informational meeting I was at they asked for suggestions for supercharger locations. And I know there is a bunch of individual local discussions of best places to place a supercharger. I made another map in ZeeMaps for placing in your suggestions.
    Tesla Supercharger Desired Locations
    • To add a marker, use the "Additions"/"Add Marker - Detailed or Simple" drop-down.
    • Use your reservation number followed by dash and your personal ranking e.g. "P1635-1" or "S42 (EU)-1" (1 would be highest priority for yourself)
    • Please follow the color-coding convention in the legend at the bottom: green=90kW charger, lightgreen=20kW, lightblue=10kW (chargers should have lower levels at same location)
    • If there is someone else with a reservation already in your desired location, please place your marker slightly to one side; otherwise, it will not be visible.
    • If someone else already placed a marker near your desired location please be sure to place another marker there. The high frequency marker locations (from different reservation holders) can be the biggest signal to an Ideal location. You can turn off other posting by clicking on the ledge on the footer of the map - then you should be able to place without the other marker interfering.
    • Try to be as specific as possible for the location - since this is a location you specifically would desire you should know what is in the area already. These markers are for trips you should be doing regularly.
    Try to keep your suggestions for places that you would utilize only (<10 locations) . Hopefully others will choose similar locations and would send a signal to TM of what locations would be useful.
    Traveling speeds affect distances - here is a approximate guide of ideal distances :
    [td rowspan="2"]
    [/td]
    [/tr]
    Max Range (miles) 40kWh 60kWh 85kWh
    55mph 160 230 333
    60mph 150 213 307
    65mph 136 197 283
    70mph 128 182 260
    75mph 116 169 239
    80mph 109 156 219
    80% MaxRange (miles) 40kWh 60kWh 85kWh
    55mph 128 184 267
    60mph 120 170 246
    65mph 109 158 226
    70mph 102 146 208
    75mph 93 135 191
    80mph 87 125 175
    Wh/mile usage 40kWh 60kWh 85kWh
    55mph 250 261 255
    60mph 267 282 276
    65mph 294 305 301
    70mph 313 329 327
    75mph 345 355 356
    80mph 367 383 388
    60 and 85 kWh packs match with my calculations to new Model S Efficiency and Range | Blog | Tesla Motors values
    km/h mph Wh/mile Wh/km miles 85kWh km 85kWh
    150 93 483 300 176 283
    140 87 436 271 195 314
    130 81 393 244 216 348
    120 75 354 220 240 387
    110 68 318 198 267 430
    100 62 286 178 297 478
    References:
    Highway Range Ignorance
    EV Time Distance Chart Calculator
  2. Bearman
    Bearman Member
    Sweden
    I think its partly because the wh/mile numbers for the 40kwh pack are erroneous.
    Using your data for range at 80mph:
    85 kwh/213miles= 399 wh/mile
    60kwh/163 miles= 368 wh/mile
    40kwh/109 miles= 367 wh/mile.
    you have 400 wh/mile, 367 wh/mile and 345 wh/mile numbers in your wh/mile table. Coincidentally 40kwh/116 miles (75 mph number) = 345 wh/mile suggesting something like an excel row shift error.
    Thank you for the tables.
  3. VolkerP
    VolkerP EU Model S P-37
    Germany
    made some additions for the German Autobahn Netz.
    Many thanks to daxz for seizing the initative! Can you add some tables with ranges in km and speed in kph? Mind you, 150kph is a convenient cruising speed here!
  4. mklcolvin
    mklcolvin #P-5058
    Shreveport, LA, USA
    Dallas/Memphis/Chicago added - that was fun!
  5. daxz
    daxz Member
    Denver, CO
    edit initial thread posting adding in km/h chart for 85kWh pack
    at 150 km/h you can go a max of 270 km w/ 85kWh pack
    You are also getting close the limit of where the supercharge can sustain that velocity over long distances. For some distances it's quicker over all to slow down then it is to stop to charge.
    Max sustained velocity for charger sizes.
    charge ratemphkm/h
    90 kW108173
    59 kW93150
    31 kW75121
    20 kW65104
    10 kW5183
  6. zdre
    zdre 40kWh Model S, Model 3LR
    St. Louis
    Wh/mile usage chart is incorrect for 60kWh... Shouldn't it be 261Wh/mile at 55mph?
  7. daxz
    daxz Member
    Denver, CO
    I had 240miles as max range for 55mph in my calcs. I've re-adjusted my calcs with the 60kWh pack sizes above to hit 230miles @ 55mph. Thanks for pointing that out!
    Still don't know why the 60 vs 85 would have the hit of 22Wh/mile.
  8. Mark Petersen
    Mark Petersen Model S EU P71
    Hørsholm, Denmark
    lol
    I have just filled Denmark with all the optimal locations
    mostly ferry crossings
  9. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    daxz: Great idea. Have you e-mailed Tesla with this map? I'm sure they probably already know about it but might be good information for them. Thanks.
  10. W.Petefish
    W.Petefish Active Member
    +1. It'd be not just good, but GREAT information for TM. It'd also solve a lot of the headaches of finding suitable sites. If we already have cities in mind, it'd save them time and trouble of finding places. They'd just have to scout within city limits, not look for cities to put them.
  11. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    The one that I really want to see, that I added to the map is at the Clemson University International Center for Automotive Research. It happens to be pretty much halfway between Charlotte and Atlanta, and well is also directly on I-85.
  12. Rifleman
    Rifleman Now owns 2 Model S's!!!
    Harrison Ohio
    A charger in Greensburg Indiana would be my number 1 point. A level 2 charger in this location would allow for me to drive a 40 kw Model S between Cincinnati and Indianapolis without worry, and a Level 3 charger would be a great top off point for 85 KW models going between Cincinnati and Chicago (this trip is just barely out of range without a charge)
  13. dadaleus
    dadaleus 4GETOIL P85#S70,FdrX,S85D
    Solana Beach, California, United States
    #13 dadaleus, Apr 6, 2012
    In the US, I think it makes the most sense to do these are places that are what I'd call "travel centers." A great example is at the Laval Road exit fro I5 just North of the grapevine in Califonria. There you can find a Starbucks, In-n-out burger, Chipotle Grill, Panda Express, and McDonalds. It's also along the busy I5 cooridor, and a nexus with other major routes like Freeway 99 and routes from the coast, 127 miles south of the already identified Coalinga Supercharger. These kinds of places don't exist everywhere we'd need them, but it seems an ideal way to stop and plug in, use a bathroom and grab a quick meal, and hit the road again. I've marked a few of these I know of the map (since I travel that route often).
  14. Tempus
    Tempus Member
    Virginia
    there's a whole host of those up and down the I-95 corridor on the east coast as well (and i agree - ideal locations for chargers). On the routes that i generally travel, that would cover Maryland, Delaware, New Jersey, etc...
  15. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    @Tempus: same in New England. Rest stops along the Mass Pike (I-90) are well-spaced and provide services to spend time while charging. The rest stops on the Maine Turnpike are also good targets, especially the Kennebunk area--putting one there would really open up the Maine coast to EV driving. Maine is a wasteland of EV charging right now.
  16. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    Why exactly is a ferry crossing a good location? An electric car won't exactly use very much electricity while on a ferry. It might even be able to charge while on the ferry.
    I would have thought Denmark really only needs two superchargers. One in close proximity to the bridge to Sweden, and one where the E20 meets the E45. For good measure there might be one near Aalborg. Hirtshals to Copenhagen is 480 km, which means the entire country is inside the range of a Model S. That means you really only need supercharging when leaving Denmark.
    Anyway, I addded som suggestions for Norway. Mostly at the midway points between major cities.
  17. Yggdrasill
    Kongsberg, Norway
    I decided to add enough charger locations to reach the entire country relatively easily. I would be very surprised if Tesla decided to install chargers north of Trondheim, but it would be quite awesome. Then any car vacation I would like in the entire country would be possible.
    You really only need 16 superchargers to cover the entire country, though. That's probably less than $2 million. Good value for money. :eek:
  18. Yggdrasill
    Kongsberg, Norway
    Looking at the numbers, it is possible that Tesla might decide to implement a Supercharger grid like the one I laid out. Already there are around 300 reservations for the Model S in Norway, and if we assume Tesla will be able to sell that many cars each year, Tesla would need to use less than 1% of the revenue on Superchargers.
    I think Tesla would be able to easily sell enough cars to offset that cost, based on the advertising value of having the grid. Traveling from Lindesnes to Kirkenes mostly on the E6, would take 42 hours, if you had two drivers that alternated on sleeping/driving, and they only ate at my specified charging locations. That's a distance of 1800 miles. Doing it in an ICE car would be 37 hours, with no stops at all.
    The grid would allow Tesla to sell the idea of the unlimited range electric car, and that should resonate with buyers.
  19. jerry33
    Texas
    A ferry crossing is a good location because you're stopped anyway, so you might as well charge up there as someplace else. Almost all the ferries I've been on had a significant wait before you actually boarded the ferry. Also charging while on the ferry doesn't help reduce the use of fossil fuels.
  20. Yggdrasill
    Kongsberg, Norway
    I'll agree a ferry crossing can be a good place to charge, but it depends entirely on the circumstances.
    Most ferries I've had to take means queueing up to enter the ferry, as it spends as little time as possible unloading/loading cars, and it would be hard to charge while in the queue. To put up a Tesla charger would mean that the ferry company would either have to give electric cars special treatment, or it would require the EV driver to park and charge while the ferry is approaching, and then when cars start to be loaded, join the back of the queue. (This last option wouldn't really work on a number of the ferries I've taken, as there is no guarantee there is actually room for your car, so joining at the back of the queue might mean having to wait for the next ferry.) I think we will need a larger number of EVs on the roads before the ferry companies will be willing to change their loading procedures, but of course, one can at least try to affect their views.
    Furthermore, if the destination of the ferry is also the final destination for most people boarding the ferry, it makes little sense to put up chargers, because the EV will almost definitely be charged at the final destination. So, this aspect will need to be assessed - will most people need to have full charge when the ferry unloads them?
