Summer Tire replacement - stay with 21", or drop to 19"
Discussion in 'Model S: Driving Dynamics' started by dj905, Aug 21, 2014.
  1. dj905
    dj905 Member
    GTA, Canada
    My 21" summer tires are worn out (again), and I am trying to assess the options:
    - stay with 21" Continentals
    - switch to 21" Michelin
    - switch to 21" Hankook
    - drop down to 19" Michelin PS3 or AS3 with T-sportline wheels
    There are several questions in my mind:
    1. Cost? How much better is the tread wear with 19" performance tires over 21"?
    2. Performance? Am I likely to notice much performance difference if I go with 19" performance tires?
    3. Are the T-sportline wheels less susceptible to curb rash?
    The simple answer seems to be.. just stay with the 21" Continentals... is that the best answer? Fortunately, all four of my tires need to be replaced, so I can more easily make a change this time.
    David
  2. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    Cost is difficult because obviously you have to factor in that if you go to 19"s you're buying new wheels. You'll save money on tires, but whether you make that cost back or not will depend on how long you keep the car. The tread wear should be similar between the 19"s and 21"s given identical tires. There's nothing inherent to the 21" size that's resulting in increased tread wear, it's the combination of rear camber/toe (also present when running 19"s) and soft compound tires.
    The contact patch of the stock 19" sizing is actually slightly larger than that of the 21"s, but that will be offset by the flex in the increased sidewall height. Further, the contact patch on the 19"s is longer and narrower, and length of the patch is one of the primary factors in rolling resistance. The difference is small, but given equal tires you may see slightly reduced economy on the 19" version. I suspect in anything but aggressive track use you'll notice no discernable difference between the 19"s with summer tires and the 21"s with summer tires.
    T-sportline's wheels will be less susceptible to curb rash simply because of the larger sidewall height. The larger the sidewall, the less likely curb rash becomes. They won't be immune, if that's what you're looking for, though.
    If I had the 21"s and was looking for a high performance summer, I'd be looking at Michelin's Pilot Super Sports over another set of the Continentals.
  3. omarsultan
    omarsultan Active Member
    Northern California
    I believe treadwear is going to be more of a function of the tire compound than the size - check the UTQG ratings of the tires to give you a rough estimate of how they will wear (note the keywords there are "rough estimate).
    In terms of performance, depends on how hard you drive and how attuned you are. In theory 19" wheels are faster of the line than 21" wheels because they have less rotational inertia--I the real world, I am not sure if the difference is material or noticeable. The 45-series tire on the 19" wheel will have more sidewall flex than the 35-series tire on the 21" wheel, which, in theory, will make a difference in cornering. Again, it will come down to how hard you drive it and how attuned you are to the car.
    O
  4. jkirkebo
    jkirkebo Model S P85+ VIN 14420 EU
    Fredrikstad, Norway
    Several owners in Norway have switched from 21" Contis to 21" Michelin PS2 and have reported two to three times the mileage per set compared to the Contis.
  5. Zextraterrestrial
    Humboldt/Los Altos
    Personally like 19" better than 21" in every sense besides the look. quicker and better handling + better wear
  6. AndreyATC
    AndreyATC Member
    Cape Coral FL, USA
    If you go aftermarket, might as well drop to 20, not to 19s
    You could get PSS tires with better 255/285 sizes
    I just did this and my car transformed into amazing sports car
    The amount of grip is endless
  7. linkster
    linkster Active Member
    USAX2
    Say......have you entered your ballot to show TSportline the demand for 20" turbines?
    Do You Want TSportline to Produce 20 Turbine Wheels?
  8. AndreyATC
    AndreyATC Member
    Cape Coral FL, USA
    No, but I do feel that 20 inch is perfect wheel size for this car, especially with just a tad wider rubber
    Here is my 255/285 PSS on Vorsteiner rims
  9. linkster
    USAX2
    Awesomeness light, strong, 20 forgies!
  10. LuckyLuke
    LuckyLuke Model S P90DL
    Eindhoven, The Netherlands
    You don't use the brakes a lot, do you? ;)
  11. AndreyATC
    AndreyATC Member
    Cape Coral FL, USA
    Nah, my car just happened to be sitting there for a few days, while we were on vacation
    Maybe i should have driven it before snapping pics
    LOL
  12. Liz G
    Liz G P03056
    Wentzville, MO
    Here is a picture of Lithie with the mat black T-sportline 19's.
  13. mknox
    mknox Well-Known Member
    Toronto, ON
    He likely just washed the car. I can watch my brakes turn that color right before my eyes as I wash/rinse the rims in my driveway.
    EDIT: Saw the post about it sitting. Mine will do that too if it's humid.
  14. bigdomer
    bigdomer Member
    Franklin, TN
    As Gizmotoy said, I will be going with the Pilot SS's. Had those not come out in the proper fitment for the 21's, I would have ordered the 19's.
  15. linkster
    USAX2
    a) stay with 21"
    b) drop to 20"
    c) drop to 19"
    I am going with AndreyATC's answer: a definite "b".
    Maybe someday, my favorite car, built by my favorite employees, run by my favorite CEO will stop offering heavy, damage prone, alignment sensitive, gorgeous 21's as an option and instead offer 20" turbines. Tesla could still sell 21" turbines as an accessory item to owners that don't mind the extra expense (i really wanted to say, "have money to burn") on a 21" wheel/tire combination.
  16. Blathering1
    Blathering1 Remember
    USA...Carolina...Chapel Hill
    The prone to damage is the real bell ringer against the 21's.
    While some road craters will impact a 19, 20, and 21, a minor road impediment will damage the 21 tires, and likely the rims. Examples of environmental risks to the 21s: a metal road surface plate, pavement cut for resurfacing. Most car tires sail over these, the 21 is too short to absorb the abrupt impact.
    Do 20s have sufficiently taller sidewalls that they remove the road impact risk of all but the most severe cases.
    Has anyone damaged a wheel on a 20" on their MS, or bubbled a tire from a road obstacle that other cars (or 19's) are not impacted.
  17. AnOutsider
    AnOutsider S532 # XS27
    To toss my hat into the ring, I dropped to 19's and am far happier. I don't have performance tires, but I haven't rashed or bent a wheel yet, and my alignment seems to "stick".
    Also curious of the experiences of the folks that went to 20"
  18. simplesolar
    simplesolar Member
    SoCal
    went down to 20" and it opened up a lot of tire choices for cheap. I am projecting 40k rear and 50k front on my staggered 20"s on michelin pilot supersport.
  19. dj905
    dj905 Member
    GTA, Canada
    Decision made and implemented. I have gone with my option #4 - 19" T-sportline wheels with Michelin Pilot Sport A/S 3 tires. My initial reaction is that they are quieter, somewhat smoother than the 21" Continentals, and my performance seems to be similar when launching from a stop for example.
    If someone is interested in purchasing some 21" wheels (afflicted with curb rash), they have been posted for sale - I'm open to offers!
    Thanks everyone for your input.
    David
  20. doc@tirerack
    South Bend, IN
    Keep us updated with any longer term feedback, its always helpful to get perspective from someone that has used both wheel diameters !
