I received my new Model S two days ago and when I got home I discovered that it is as wide as my Ford F150 truck. Therefore it's very difficult to get into my garage which is really a bay in my 200 yr old barn. Because of the aerodynamic rounding of the body I cannot see the front or rear fenders of the car from the driving position so it's nearly impossible to pull through the 7'10" wide doors without a lot of stress. Unfortunately I installed the charge outlet in there so I need to get in to charge the car.
Looks like a job for auto park! Except auto park cancels every time I try it. I also set the parameters for a tight garage. After a long discussion with the local service center we think the problem is that it's uphill into the barn and auto park is meant to work on level ground. Now, the angle uphill is maybe one foot rise over 25 feet distance. It's a gravel driveway so I'm considering adding a lot of gravel to make is level.
My question is, has anyone else encountered this problem and do you think this solution will work? We can't exactly pinpoint the problem so we are guessing it's the grade. Does anyone have a problem with a garage opening as small as 7'10"? Remember, I did set the parameters for a tight garage.
Thanks
Thanks
