Summon + Backup Lights (daytime)
Discussion in 'Model S' started by amallah, Apr 21, 2016.
Tags:
  1. amallah
    amallah Member
    Monkton, MD
    I can't tell if this is a bug/service issue or a feature request - but when I summon the car in reverse in the daytime, the backup lights don't turn on. They do at night. Shouldn't they always be on? My use case is that I'm in a parking lot and I'm backing out of a space as I walk towards the car - but I'm worried that other drivers in the parking lot will not be expecting a driverless vehicle on the move (imagine that).. Am I wrong?
  2. msnow
    msnow Active Member
    SoCal
    Makes sense.
  3. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Maybe Tesla assumes that you wouldn't start "Summon" with other cars approaching?
  4. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    When I use summon, I am usually standing nearby. If a car is approaching, I stop summon and wave them on -- unless they insist on sitting and staring. I can restart summon and back out far enough to get in the car, and we drive away. I've never had a problem.
  5. Eugene Ash
    Eugene Ash Member
    Issaquah, WA
    Sorry for the noob question: is parking into a narrow spot possible: 1 come into an office garage 2 find a narrow spot 3 step out of the vehicle 4 instruct the vehicle to take that spot. 5 go conduct business. 6 come back 7. Summon the car out of the tight spot?
    Is it doable?
  6. amallah
    amallah Member
    Monkton, MD
    Of course not. I would also not get into a car without Summon and start backing out while other cars are approaching expecting the lights to be sufficient warning.
    The scenario is that summon has started, and another car approaches during the summon. Of course I can hit stop, but now there is a stopped car in the middle of a parking lot with no lights or driver. The point of the lights is for the other driver to be aware of the direction and motion of the car. From the back of the car in daytime, it doesn't look any different on or off.
    Yes.
  7. AZ Desert Driver
    AZ Desert Driver Rare combination
    Tucson AZ
    I can see Summon into a tight space where the walls make the space tight. But if you park your car so close to my car that I can't get into it - well, Houston we have a problem. If is is sorta-tight, then I bang my door into you.
    I am excited about the usefulness of Summon - I just hope "misuse-abuse" does not cause a backlash.
  8. RogerHScott
    RogerHScott Active Member
    Lafayette, IN
    How 'bout if you park your car so far to the right in your space that you're crowding the space to your right? You'll have plenty of
    room to get out on the left if I park close to you on the right (but only in the center of my spot). I don't want to encourage someone to
    ding me, but are inconsiderate parkers really just given a pass for taking up two spots?
  9. AZ Desert Driver
    Tucson AZ
    Ahhh - left side/right side crowding..my parking is better than yours...a topic where the only solution is to be good neighbors. And there are always bad neighbors. Summon may fix some conditions - good thing. But they COULD also let a Tesla driver become a bad neighbor.
    My hope again is that misuse/abuse is a minimum and does not cause a backlash.
  10. amallah
    amallah Member
    Monkton, MD
    Okay, so what I'm gathering from this is that it's not just me, the backup lights do not turn on if you are summoning in the daytime.
    If that was the logic, this doesn't explain why it the backup lights do turn on at night (when the headlights/taillights are on).
  11. brucet999
    Normal backup light behavior? Nothing special when in "Summon" mode?
  12. kort677
    kort677 Banned
    florida.
    on my car the back up lights always turn on when using summons to back the car out of a spot.
    does anyone really use summons while seated inside the car?
  13. RogerHScott
    Lafayette, IN
    Yes. I usually summon to/from outside my garage, but if it is raining I'll get/stay in the car. Being in the car in no way diminishes
    the value of the car maneuvering through my somewhat narrow garage door entrance. That value isn't realized every day; it will
    be realized on the day when I'm super tired, distracted, and in a hurry, when, left to my own devices, I might put a multi-hundred
    dollar (or worse) scratch or dent on one side. The car may stubbornly refuse to move now and then, but I'm confident at this point that
    it won't run into anything (certainly not any of the "standard threats" in this environment).
  14. zambono
    zambono Active Member
    DC
    Per the manual wasn't summons supposed to be used in private property, as in your garage? Parking areas are also private property but I think Tesla means your own. Another observation if you are parking so close to other vehicles in a public parking you are asking for dents, and if other drivers are not as nice being keyed and such
  15. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    My lights come on during the day..when it works...
  16. AZ Desert Driver
    Tucson AZ
    This makes so much sense --- being super careful when fully awake so that when your tired and distracted the machine saves your bacon. I pull in and out of my garage and always miss the door frame, until someone leaves the radio on or asks about my coffee cup and I get distracted and --in the blink of an eye - baam goes the mirror.
  17. brucet999
    Summon has been useful for me twice in parking lots where someone has parked uncomfortably close to my driver's door.
  18. roblab
    I would say that's what it's for. Make sure you set up your car for narrow parking, and you will probably need to watch and tell it when to stop.
