Summon from auto park (parallel / perpendicular parking)
wayeq
New Member
Dec 6, 2017
2
0
california
New MS owner. From the manual, I am lead to believe that the car can pull out and return to the original position (parallel or perpendicular to the parking space):
"You can summon Model S back to its original position if you previously auto parked it and the
vehicle has remained in the Park gear. Then, using the mobile app or key, simply specify the
opposite direction. Summon moves the vehicle along the original path provided the environment
has not changed (i.e. no obstructions have been introduced)."
This would of course involve steering left or right as the vehicle un-parks, to return to the location where you engaged auto-park. So far my car will only pull straight out in a straight line from a perpendicular parking spot, when I use summon (in other words, it does not return to where I engaged auto-park)
Just curious if this is working for everyone but me, or if I'm missing something, or if I've misunderstood the owners manual.
Thanks!
Derek Kessler
1,193
1,800
Cincinnati
Summon only works in straight lines. Okay, it'll turn slightly to avoid an obstacle, but other than that: straight forward or straight back.
Autopark and Summon are two separate and currently uncomplimentary features.
wayeq
New Member
Dec 6, 2017
2
0
california
Right, that is my observation, however the quote from the user manual would imply they are not completely unrelated. Maybe the manual is just poorly worded. Thanks for the response!
