Firmware 2.12.126 seems to have introduced a new summon defect. I use summon daily to park in my garage as it a bit narrow and using summon helps prevent me from dining m doors. Since loading 2.12.126 the car pulls into the garage just as it has before even stopping in the same place. The difference is that summon stays active, like it is trying to figure out if it should pull further forward. You can see the steering wheel rotating back and forth, and the display shows the car and the distance from the wall in front of the car. I have to abort summon with the FOB. Oddly enough the car does close the garage door via homelink, something it normally only does once summon is complete. On the way out everything works as it used to, the car backs up, opens the garage door, pulls out of the garage, summon completes, and the closes the garage door via homelink. I received the 2.13.103 update a few days ago and the behavior is the same.
