Summons Stops
Discussion in 'Model S' started by ED Red, May 13, 2017.
Tags:
  1. ED Red
    ED Red New Member
    Westlake Village, CA
    When backing out of garage, Summons stops with car about 1/3 out. When I restart Summons, car completes backing out. Occasionally the car will back out without stopping. Clearance is about 5 -6 inches, Anyone else having this problem ? I am on 17.17.4, same thing on previous update
  2. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    Is there a lip, threshold, change in slope, or other seemingly minor obstacle that a rear wheel is encountering at that point?
  3. Scott-P
    Scott-P Member
    Tacoma, WA
    I'm still on 17.11.45 and mine does the same thing (although in my experience it varies from 1/3 to 3/4 of the way out when it stops...). It also sometimes stops while moving into the garage, which seems worse if it isn't started EXACTLY straight on to the door frame. Other than the alignment on entry, it seems pretty random. I suspect that the side sensors are the cause, and it is over-interpreting their data. Hopefully this will improve in the next few firmware updates...
  4. ED Red
    ED Red New Member
    No, worked perfect on my Model 85D with AP1, I now have a 100d with AP2
  5. pilotSteve
    pilotSteve Active Member
    Vancouver WA
    Are you on wifi in the garage? I ask because Sometimes mine starts backing out then stops half way and the app says it lost connection to the car. When I reconnect (takes a few seconds) and press reverse again it resumes and completes. Wondering if it switched from wifi to LTE and that interrupted the summon.
  6. croman
    croman Active Member
    Chicago, IL
    It seems to give up if there is even the tiniest difficulty. Sometimes works great, mostly gets half out and gives up. Hasn't tried to close the garage on itself though!
  7. ED Red
    ED Red New Member
    worked good on my previous TESLA, AP!, Model S 1015
  8. Joe F
    Joe F FUD Buster
    Outside Philly
    Mine balks on head in entry. Always fails first time dbl pushing park; Using fob to restart always works. Narrow frame. Starting with fob only works about 50% on first attempt, with second attempt continues straight without steering and completes. Very slight lip but not the issue because bumper not even close. Tried pulling in partially first, that too is 50/50. No slope driveway to slab.
    Frustrating, but better than manually parking and hugging one wall to exit car in a small garage.
  9. croman
    Chicago, IL
    I have an issue where when backing out the garage door opens and car doesn't detect garage door isn't there. It then gives up. Works second time around.
  10. rahs
    rahs Member
    NJ/NYC
    We have a "long" garage. It's only wide enough for one car and but two cars can park in it one in front of the other. If the Tesla is parked all the way in the front reverse summons doesn't work. Not sure if it's the distance (extra ~15 feet). Or if the space is too narrow for a longer distance.
    If it's parked closer to the opening I usually don't have a problem but sometimes it takes two summons tries to get it out.
  11. ACExpress
    ACExpress Member
    Dallas, TX
    I have the same issue. I activate summon on AP2 using the key fob. Pretty narrow clearance on each side in the garage. It executes perfectly about 1/3 of the time. The other 2/3 is some combo of needing to back up and straighten up the car or just needing to restart summon on the fob. Same issues forward and reverse.
  12. bob_p
    bob_p Active Member
    This happened to me this morning. Stopped as it was partly out of the garage. After several unsuccessful attempts to restart, was able to get the car out of the garage with summon mode.
  13. dknisely
    dknisely Member
    Seattle, WA
    I can confirm an identical change with 17.17.4 vs. 17.11.45. At first, I thought it was a fluke, but something is definitely causing it to stop early most of the time (forward exit from my parking space only). Backing into the space works every time, including crossing a ~3/4" lip. The strange thing is that it doesn't stop anywhere close to either set up tires being on the lip, so I don't think it is related to the lip. I just restart the summon and it continues.
  14. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ In loving memory of Version 8
    Portland, Oregon
    I've used summon at least six times to pull my car in and out of the garage. Always using the fob. It has worked well each time. Today it scared me a bit. It backed up about a foot out of the garage and stopped. I re-initiated summon and it backed up a few more feet, stopped, turned its wheels to the right and continued backing up. If I hadn't stopped it, I'm guessing it would have ran the front door and front quarter panel into the side of garage. Obviously I can't trust this feature anymore.
