SunPass Mini
Discussion in 'Florida' started by ElliottWeinstein, Jan 15, 2015.
Tags:
  1. ElliottWeinstein
    ElliottWeinstein New Member
    York, PA
    I'm a Pennsylvania resident, visiting Florida in my Tesla S next month.
    Does anyone know if the SunPass Mini works any better than the regular transponder?
    I already have the front bumper special transponder for EZ-Pass in PA, and didn't won't to go through the bother of a new front transponder for just one month.
    Suggestions?
  2. pgiralt
    pgiralt Supporting Member
    Cary, NC
    While not directly answering your question, have you checked to see if EZ-Pass is accepted in Florida? My NC Quick Pass front bumper transponder (behind my nose cone) works fine in Florida Sun Pass stations (as well as with EZ-Pass up north).
  3. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    Just tagging in this thread. I'm in Florida for a few days, and I do have a Sunpass "mini" stick-on RFID tag. But it sounds like nobody has really found a good position other than holding it out the window or sunroof --- is that 100% effective?
    Also, I've added my car and tag # to the Sunpass website, so they have a record of my car there.
    Exactly which tolls now still have the gate arms and which ones will do the photo/plate detection if the Sunpass tag isn't picked up?
    I'll mostly be going from the Universal/Disney area to the Orlando Supercharger, and then from Orlando down to Vero Beach. Does the Yeehaw junction toll still have gate-arms? When I went through there a few years ago in a rental with the sunpass mini, I held it out the window, it didn't read, and I couldn't get the gate to go up, really pissing off about 6 cars behind me. It eventually worked and I got through.. I'd just like to avoid that again if at all possible, so I'm hoping those tolls now can do the license plate photo reads.
    thanks.
  4. BlkCld
    BlkCld Member
    South FL
    #4 BlkCld, Jan 19, 2015
    Mine has been mounted here for a year and no issues. My plate is also registered to the sun pass so even if it doesn't sense it Sunpass just deducts the toll from my account instead of sending a toll by plate bill.
  5. HankLloydRight
    Connecticut
    I have the Sunpass mini -- just a flexible plastic card with the RFID in the middle. I went through 3 or 4 tolls today holding it outside my open window, and it would not read. I'm just hoping it captured my license plate number on my account.
    How long does it take for the license plate reads to hit my Sunpass account?
    Also, does the license plate reads also work in EPass roads with my Sunpass account?
  6. BlkCld
    BlkCld Member
    South FL
    The mini actually needs affixed to the window. I have in my other cars and it states it uses the window as an antenna. It is non removable without destroying it.
    I never actually checked how quick they apply the toll by plate to the account.
    I don't have an answer about the Epass.
  7. HankLloydRight
    Connecticut
    Ok, that makes sense, but with the MS windshield blocking the radio waves, mounted on the windshield or not, I guess it won't work. I might try mounting it on the outside or the nose cone. Is there a document somewhere that describes how it uses the windshield as an antenna? Seems strange to me.
  8. LoL Rick
    LoL Rick Like Buttah
    Land O Lakes, FL
    If you don't have window tinting film on the windshield, then I recommend trying the mini stuck to the shaded part just to the right of the mirror. Some windshields will work and some won't. But it definitely will not work without being stuck on the windshield - I know that from experience with other cars. There is a note here: Sales Locations
    that says this: Note: The SunPass Mini Sticker transponder will only operate when affixed to glass windshields. They are not designed for use on motorcycles.
    As for posting time, license plate reads generally take a day or two while transponder reads post much faster.
  9. BlkCld
    BlkCld Member
    South FL
    I highly doubt mounting it to the nose cone would work since its plastic. Sure is a puzzle for short term use. The suction cup one is the best option but its $25. Not really worth it for short term use.
    May not be worth the hassle versus just paying cash tolls. Sunpass is maybe a 25-50 cent savings per toll. Problem is the exits that are sunpass only. But then those have the toll by plate cameras.
    As long as there are no gate arms you should be set to get the cheaper tolls through the toll by plate billing to sunpass account scenario.
    I have used my sunpass on the EZpass toll road that runs east west just North of the MCO airport. I think it was the Beeline route 528.
    Hopefully someone else has a good idea for you
  10. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    Mine is not stuck to the window. In fact it would not work at all when stuck to the window. Mine is stuck to the rear view mirror and works 90% of the time.
  11. Brit4864
    Brit4864 Member
    South Florida
    It works well mounted in the nosecone. At least the license plate transponder version works ok. I've had mine mounted since Sept 2013 and it works every time. The photo isn't of mine but I have it mounted in exactly the same way.
  12. LoL Rick
    Land O Lakes, FL
    Let's be clear that the OP is talking about a Sunpass mini, which is a very different thing than the regular transponders. It's basically a sticker that has a tiny chip in it. I've had them in previous cars and they would not work without sticking them to the windshield. They also would not work if peeled off and stuck to a different car.
  13. aviators99
    Also, keep in mind (as mentioned before), mounting in the nose cone doesn't work in SE Florida, as you will be billed for the I-95 express lanes. You have to remove/shield the transponder when you are in these lanes so that you don't have to pay (up to $7.50).
  14. robaross
    robaross P4550
    SFL
    ^ This may not be true. I was informed, direct from ExpressPass that Sunpass is set up to delete the Express lanes charges from accounts whose cars require an outside transponder (like the Model S), and if this does not happen automatically, you can call Sunpass and the charge will be removed. Just check your statement on line each month.
  15. Racerx22b
    Racerx22b @unplggdd on Instagram
    West Palm Beach, FL
    So has anyone actually applied the Sunpass Mini or the portable Sunpass (the one with the suction cups) to the Model S window and had it work consistently? Seems like BlkCld has the portable one working. I posted a thread a week or so ago with some concerns I had from the issues reported on this forum and someone stated that the window has been fixed to allow EZ pass signals to pass thru. This person has over 4000 posts so I would like to think they know what they are talking about but perhaps they don't.
    Click here for link
  16. Larry Chanin
    Larry Chanin President, Florida Tesla Enthusiasts
    Sarasota, Florida
    #16 Larry Chanin, Jan 21, 2015
    Hi,
    I don't know if the windshield design has changed, but I have the original windshield and have had no problems getting the portable SunPass with suction cups to work. What I did was Velcro the transponder to the back of the rear view mirror stalk. I find that it is less conspicuous and works better than mounting it on the windshield.
    By the way, if you are interested in joining our Florida Tesla club, please click on the link in my signature.
    Larry
  17. robaross
    robaross P4550
    SFL
    I have an early (Dec 2012) Model S and the portable works inconsistently mounted just below the windshield dots in front of the mirror. Any lower and it never works. I have never received a notice from Sunpass. Charges are then based on license plate reading. This is not a problem when your Sunpass is in the car with the correct tag, but if you move it into another car (visitor from up north?) you may have a problem. I will be having Tesla Service Center install an external Sunpass beneath the nosecone at my next service visit.
  18. Larry Chanin
    Sarasota, Florida
    Hi Robert,
    I also have a an early December 2012 Model S and I have found that the portable transponder always works when Velcroed to the rear view mirror stalk rather than being mounted on the windshield. 100% of the time I always get the green light Thank You acknowledgment with this arrangement.
    For those people on the East Coast of Florida that have the HOV stickers that permit them free access to the HOV lanes, this arrangement is very convenient because the transponder can easily be removed and shielded. For those people with the transponder mounted in the nosecone it is not possible to turn off the transponder by shielding it. Therefore, despite having the HOV sticker they would be charged while traveling on the HOV lanes.
    Larry
  19. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    I tried the suction cup model in many different locations, including velcroed to the mirror stalk, and it never worked - nada, zip, zero. I now have the external version mounted under the nosecone (service center did it for free in about five minutes).
  20. aviators99
    Here is my setup (December 2012). Works very well. Note that the mirror on top is exactly the right width for this type of Sunpass. Remove the suction cups and velcro it upside down like I did. I know I've posted this before, but I think this is a better picture.
