Sunshade for back passenger window
Discussion in 'Model S' started by Sus, Aug 12, 2016.
Tags:
  1. Sus
    Sus Member
    Southern California
    Does anyone have a recommendation for a sunshade for the back passenger window? I already have our windows tinted but the sun still hits my toddler pretty strong when he's in the car seat. I've tried some mesh ones that stick on with a suction but none that I've tried really fits. Also the suction inevitable fails. Thanks in advance!
  2. mblakele
    mblakele pre-jackpot member
    SF Bay Area
  3. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    The rear liftgate sunshade is great, almost a necessity in California. It does help reduce temperature in the back, and as a bonus, it reduces headlight glare at night. Definitely recommended.
    But the OP's question was not about the rear liftgate window, it was about the back passenger (side) window and preventing sun from hitting a toddler in a car seat. I don't have any good suggestions there, other than to suggest tinting, which was already tried. If you have the pano roof, maybe you can get a couple of plastic coat hooks and hang a blanket from them?
  4. RYCO
    RYCO Member
    Gilbert AZ
    I used these. I put the large screen type over the front pano along with the little ones between the shade and the glass to give a little more blockage. They have the suction cups but it also fits snug in the cracks. You will see what i mean. Very cheap compared to the tesla version. Got them at auto zone. 20160813_162221.jpg
  5. PA70D
    PA70D Member
    Harrisburg, PA
    Bought the rear window sunshade from Tesla in the beginning of the summer. WE have a dog that travels in the back and it was getting too hot. The sunshade is easy to pop in, it cuts down the heat in the car dramatically so I recommend it. You might also want to search posts on cooling in the third row seats. Some time ago found a post that in addition to the rear sun shade recommended manual settings which I use that also keep the back of the car cooler. What I do is to manually set air to pull in outside air, fan on high and crack open the rear windows.
  6. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Did you get ceramic tint?
  7. Sus
    Sus Member
    Southern California
    I'm not sure if it's ceramic tint. It's the one that lots of people on TMC uses and recommends. Don't remember what that was. It keeps out heat decently well but it doesn't keep the glare of the sun from hitting his eyes/face thus the need for something in addition to the tint.
    We also don't have pano roof so aren't really able to hang anything from the roof.
  8. supratachophobia
    Columbus, Ohio
    They make those temporary place mats for kids in high chairs. Could you test one of those by sticking it to the window?
  9. jerry33
    Texas
    Heatshield makes these.
    • Disagree x 1
  10. thecloud
    Sunnyvale, CA
    Unfortunately, they appear to be only for the front side windows and not the rear side windows which the OP needs.
  11. jerry33
    Texas
    You're right. I saw rear window and thought they were for the rear side windows. If you give them a call, they might have some that aren't yet shown on the sited.
  12. Sus
    Sus Member
    Southern California
    Thanks for the suggestion but even if heatshield could make a back window cover in future, it doesn't look safe to drive with it on.
    Do you guys just have tint on your rear windows? Is that sufficient to block to glare? If so, what type of tint do you have?
  13. lmcdowell
    lmcdowell New Member
    San Francisco
    Sus, did you find a solution? We're having the same issue with our toddler in our Model X
