Super Charger very weak.
Discussion in 'Supercharging & Charging Infrastructure' started by brjr, Dec 28, 2020.
  1. brjr
    brjr Member
    worthington ohio
    Yesterday, three drivers, including me experienced very low charge rates at a super station. We were all spaced at least two chargers apart and had 35kw, 18kw and 40kw respectively. One of the other drivers said he had experienced the same low charge rate across town (Columbus Ohio).
    What gives?
  2. Sklith
    Sklith Member
    GA
    brjr, there's another subforum within this one called, "Model 3: Battery & Charging" which has an exhaustive number of stickied & not-stickied threads discussing this very topic. I suggest reading anything that mentions charging in winter. There's plenty of tips in them regarding how to consistently get higher charging speeds when it's cold.
  3. Trailblazer
    Trailblazer Member
    Cornelius, NC
    What were your states of charge when you pulled into the supercharger? Also how cold was it? Those two factors can significantly affect charging speed.
  4. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Did you check to see if you were on paired Superchargers? If so, you would've been using shared equipment, greatly slowing down the charge rate. On v2 Superchargers, try to use a Supercharger number which is not currently in use. For example, if someone is charging on 1A, don't charge on 1B if you can avoid it. You need to pay attention to the actual numbers since sometimes the chargers are arranged 1A, 1B, 2A, 2B, 3A, 3B. Other times, they are 1A, 2A, 3A, 1B, 2B, 3B or something totally different.
    For v3 Superchargers (up to 250 kW), you don't need to be concerned about getting a paired Supercharger.
  5. brjr
    brjr Member
    worthington ohio
    All cars were posted at least two spaces apart. Hmmm. Worried about this. Is Tesla throttling back power due to fires?
  6. MorrisonHiker
    Colorado
    No. Most likely you were on paired Superchargers, your batteries were cold or they were at too high states of charge.
    Try reading up on Supercharging tips or watching some videos about ways to charge the fastest at Superchargers
    • Helpful x 3
