Super fast charging rate - 433 mph
Discussion in 'Model 3' started by Merle Corey, Jul 1, 2018.
  1. Merle Corey
    Merle Corey Member
    Brambleton
    Was at the Harrisburg, PA supercharger just now (3A) and experienced a very fast charge rate. Only second time supercharging my 3, but this is the fastest by far. What’s the fastest others have experienced?
  2. P85_DA
    P85_DA Supporting Member
    I get 116-120kw in the X and S
  3. EVSteve
    EVSteve 110% Solar Powered
    Schnecksville, PA
    At 50% state of charge? Pretty good. I'm curious if that number would be higher if your 3 were down lower. At 28% I was pulling 113kW gaining 473 miles per hour.
  4. SageBrush
    SageBrush 2018: Drain the Sewer
    New Mexico
    117 kW.
    The rate tapers when SoC > 50% or so.
  5. ucmndd
    ucmndd Active Member
    The miles/hr rate is an average over the entire charging session. It will start out high and isn’t really a good indicator.
    Watch the kW number. That’s instantaneous and will give you a better idea of how quickly you’re charging.
    • Informative x 2
  6. killertofu
    killertofu Member
    Oakland
    I’ve gotten 119kw at the Truckee supercharger. I think it hit 490 miles per hour at one point on my screen
  7. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    #7 Randy Spencer, Jul 1, 2018
    Still reaching for the mythical 500 MPH
    I think this was at the Supercharger just south of Fort Collins, sadly I deleted the original
    -Randy
  8. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    I'm envious! I get about 77 kW in my S60 when it is at 10% or so and it tapers rapidly downward from there. Nevertheless, after 199 Supercharging sessions on road trips, it works well enough.
  9. ewoodrick
    ewoodrick Active Member
    Buford, GA
    I'm pretty sure that when I was down to about 10%, I saw over 500 for a few minutes as the charging began.
