Supercharge power drop to 60kW at 22% charged, with no one sharing the power
Discussion in 'Model X' started by SoCal Tsla, May 18, 2017.
Tags:
  1. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    Sorry it's so blurry...
  2. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Did you report the problem to Tesla?
  3. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    Not yet, posted this today and will contact them and give them the link to my video:)
  4. GregKo
    GregKo Member
    New Jersey
    I have seen this exact behavior last week too. MX P100D 85 Degrees outside, no one else charging. 115KW for the first 10-15% then drop to 60KW. The eta for finish charge was off by 20 min too.
  5. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    I'll mention that to Tesla too then... but where the hell did you get 115kW? The most I got was like 95, I thought the limit was like that. Was that because of a bigger battery?
  6. figers
    figers X60D Owner
    Chestnut Hill, MA
    Same thing happend to me yesterday, report back what you find...
  7. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Bigger batteries can take higher charging power.
  8. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    wil
    will do!
  9. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    That's what I thought!
  10. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    i found a work-around for this as it was happening to me on my last OH-NJ/NY-OH trip.
    basically after it slows down to 60kw i would unplug and move to another stall and it speeds up again. try not to burn yourself on the charging handle as it will be very hot.
    my conclusion was that it could sense that the handle was heating up due to the high amounts of power being dumped into the battery...
    at one Supercharger when i came back to the car and i wasn't finished charging and couldn't figure out why, then i noticed that i was creeping along at 60kw. i moved from 3B all the way over to 1A (i was the only person at the supercharger) and it immediately went shooting up to 101KW and we were able to leave 5 minutes later! :) just some of the quirks we have to deal with i guess...
    • Informative x 4
    • Helpful x 2
  11. MorrisonHiker
    MorrisonHiker S 90D 2018.26
    Colorado
    As @Peteybabes mentions, I would try another stall next time you see this issue. It happened to us once at the Silverthorne Supercharger. We moved to a different stall and that solved the issue.
  12. David99
    David99 Active Member
    Brea, Orange County
    Happened to me many times.
  13. apacheguy
    apacheguy S Sig #255
    So Cal
  14. Gwgan
    Gwgan Almost a wagon
    Maine
    That's happened to me. I did call but they didn't seem to think it was a problem, just that "that's what the car is calling for". Next time I will check out the handle temperature.
  15. MIT_S60
    MIT_S60 Member
    Orange County, CA
    60,70,75 kWh batteries are 350V batteries (max charge rate closer to 100 kW)
    85,90,100 kWh batteries are 400V batteries (max charge rate closer to 120 kW)
  16. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    The same behavior was not there in @Bjorn 's recent video, so I don't think it's normal... Tesla need to resolve this...
    I always charge at the 4A spot of the 7-stall superchager so I always have all power to myself, so I don't want to move lol
  17. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
  18. SoCal Tsla
    SoCal Tsla Member
    Irvine, California
    • Disagree x 1
  19. immolated
    immolated Member
    Las Vegas
    Call the supercharger number while you're plugged in. Last time I was in that situation, the rep was able to pull up the data and tell me stalls were showing "fluctuating power" and only stall 3a was full up. Plugged into 3a and sure enough got full 110kW.
  20. stopcrazypp
    stopcrazypp Well-Known Member
    Sometimes it's a stall issue (not handle specifically), but it can also be dirty contacts on the specific handle. This leads to a high resistance in the connection which heats up the handle rapidly (just being at night would not help very much in this case).
