Supercharger - Bridgewater, NJ
Discussion in 'Mid-Atlantic' started by Yinn, Feb 27, 2018.
Which location would you prefer?
  1. West - Off of 202 (Wegman's, Ruby Tuesday's)
    7 vote(s)
    16.3%
  2. East - Off of 287 (Bridgewater Promenade/WaWa)
    15 vote(s)
    34.9%
  3. Central - Off of 202/28 (Bridgewater Mall, Barnes & Noble, Somerville Circle)
    21 vote(s)
    48.8%
  1. EVnewbie
    EVnewbie Member
    Philadelphia
    Download plugshare and look at what the closest charging stations are. Some of them are level 1 chargers but you may find level 2 chargers hopefully near you.
  2. talhas3
    talhas3 Real Estate Investor
    Edison NJ
    I’m sure you can find a helpful EV owner Willing to let you charge at their house every now and then.
  3. EdisonFire
    EdisonFire Member
    NJ
    #83 EdisonFire, Mar 27, 2019
    Surabhis; there is a free charger at Raritan Valley Community College. It's slow so would require someone give you a ride to pick up/drop off. There are Tesla chargers in Basking Ridge section of Bernards Twp; a Supercharger site is currently under construction off Exit 36 of I-78 in Bernards Twp; there are pay chargers at Ethicon & J&J facilities in Bridgewater along with several at car dealerships; there are pay chargers at the Target store, Bridgewater. You do have choices especially in your work commute is Branchburg to Bridgewater. I too live in Branchburg
  4. paulkva
    paulkva Member
    Falls Church, VA
    I'm guessing that means your commute is relatively short, so I suggest you consider trying to find a regular 120V outlet at home or at work. Spending 8 hours plugged in to 120V can add 25-40 miles to your battery. Even if the HOA and workplace refuse to install chargers, you can ask them if you'd be allowed to use any regular outdoor 120V outlets that are reasonably close to where you park. My personal experience (mostly limited to hotels in that area) is I have better luck when I ask in person rather than via phone or email.
    If 120V at home or work isn't an option, then in addition to RVCC, the Bridgewater Nissan dealer on 22 has allowed non-Nissans to charge in the past. At some point the Basking Ridge supercharger will open, and there are also charging stations being installed at the Target near Bound Brook. Also note that if you create an account on PlugShare.com you'll be able to see residential charging locations; there are a few in Branchburg and Hillsborough.
    Even though the distance might be greater, if you go during off hours you might be better off driving to the Edison or Woodbridge superchargers rather than North Brunswick -- it should take less than 25 minutes each way, and you could combine the trip with a stop at the mall and/or some place like Harold's.
    I agree none of that is ideal -- that part of NJ hasn't been great for people who can't charge their EVs at home or work -- but you do have some options.
  5. dennisma
    dennisma Supporting Member
    Whitehouse Station, NJ
    If you wait a little the Supercharger on I-78 in Basking Ridge will be done. They are in the middle of construction and will probably finish in 2-3 months. They are working pretty fast over there on it.
    There are 4 level-2 ChargePoint stations at RVCC in Branchburg as well. If you work live in Branchburg and work in Bridgewater your commute is pretty small. Even a home charger 120v can get you about 40-50 miles of charge in one night.
  6. dennisma
    Oh hey neighbor! Been here in Readington 20 years so far. If you drive rt 523 I imagine you have an opinion about the proposed roundabout they want to put in. Had a huge gathering at the municipal bldg about it the other night.
  7. EdisonFire
    EdisonFire Member
    NJ
    JSergeant/Neighbor, I'm moving to Readington once I get zoning approval on a lot I purchased. After completing my taxes this year, I should be moving anywhere but NJ. The Somerville circle reconstruction was brilliant, the Flemington circle not so brilliant. I rarely pass the intersection you noted.
  8. thisisdiddy
    thisisdiddy Member
    NJ
    There is a Trader Joe's opening in the same mall as the Electrify America charger.
    Hopefully the Superchargers will be in the same vicinity.
  9. DeepBlue3
    DeepBlue3 Member
    The New Jersey
    Saw an electrician today opening the main panel, and going back and forth to the charger plugs, as if to test or troubleshoot.
  10. RonnieTheLimo
    RonnieTheLimo Member
    Bridgewater
    Where exactly? Is bridgewater finally getting superchargers?
  11. intelligator
    intelligator Member
    New Jersey
    I've not checked details as to what rates, cost, adapters. Target next to Patriot Stadium in Bridgewater has chargers. There's also chargers at Duke Farms. Each are pay per use.
  12. RonnieTheLimo
    Bridgewater
    Gotcha, but not Tesla chargers. Bridgewater Mall is a no brainier for Tesla chargers. Basking Ridge is making progress it looks like, i would assume that Bridgewater would be next. Anyone have any details on that?
  13. TJtv
    TJtv Member
    NJ
    I don't think there will be a supercharger in Bridgewater. The supercharger maps on tesla.com still show a Bridgwater location opening in 2019 and "timing and location will vary". The same site doesn't even show anything for Basking Ridge, which we know is already in construction.
    It seems very likely to me that the Basking Ridge Supercharger will end up being the one that Tesla identified as being in the "Bridgewater vicinity" a few years ago.
  14. RonnieTheLimo
    Bridgewater
    Makes sense, maybe we will get lucky and have one at bridgewater mall.
  15. Wick
    Wick Member
    New Jersey
    This is the picture of the Basking Ridge supercharger taken yesterday
  16. dennisma
    Last night I noticed an area over at the Mall near Macy's an area that is fenced off and there is a large drop off metal container inside the perimeter. On the fence there is a sign that the area is under surveillance.
    I don't know what is going on there but that would be a good place for the Superchargers. It's over near the Men's section and few people park over there.
  17. RonnieTheLimo
    Bridgewater
    I saw that as well, the fenced in area seems similar in size as the menlo park mall stations. Maybe we're getting superchargers after all.
  18. RonnieTheLimo
    Bridgewater
    The sign on the white box inside the fence says Richter Lighting Technologies. Doesn't seem related to Tesla, i could be wrong though.
  19. chadhyett
    chadhyett Member
    Morganville, NJ
    Where did you take that picture? I work off Allen Road but live down by the shore, so this would be a true blessing.
  20. thiyag
    thiyag Member
    Very close to a supercharger
