Supercharger - Burns, OR (or Hines, OR)
Discussion in 'Northwest' started by mociaf9, Jun 17, 2020.
  1. GHammer
    GHammer What a long strange trip its been.
    Wren, Oregon
    That's good news, I tried to use the new Chargepoint ChaDeMo a few weeks ago and couldn't get it to communicate with the car. Plugshare showed a successful Tesla connection two weeks prior to that but other people had similar issues as I had in weeks prior. Ended up sitting on the L2 for 3.5 hours which caused me to drive through a snow storm in the dark.
  2. mociaf9
    mociaf9 Active Member
    I'm not seeing any new documents besides the standard inspection reports that get created whenever anyone clicks the "Print/View Summary" button in the Record Details section. If someone wasn't familiar with the way that the Accela portal works, I can see how it might be easy to misinterpret those listings as actual action even though they aren't. Besides, the permit was already issued back in July and after issuance no more documents need or should be expected to be uploaded. It'll be nice if the tech was right about Tesla's plans to break ground soon, this location has been lacking for a long time, but there's nothing in the online record to indicate any particular new movement.
    • Informative x 3
  3. kpalaniswami
    kpalaniswami Member
    Portland, OR
    Yes, didn't realize it has been discussed already. My mistake. I was in the process of removing post. You beat me to it.
  4. mftpdx
    mftpdx Member
    Portland
    It certainly seems imminent.... The Find Us feature on Tesla's website has it opening in 2020 (Coming Soon).
    • Funny x 5
  5. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    That doesn't mean anything. It's been on the "coming soon" map for the past few years. They just run a script at the beginning of each year and update the ones that still aren't done:
    YEAR = YEAR +1
  6. mftpdx
    mftpdx Member
    Portland
    Ha ha... thanks for setting me straight. Hopefully the rest of the info is accurate and they'll have it done sooner rather than later.
  7. PLUS EV
    PLUS EV Running on Empty
    Seattle
    This would be an odd time of year to start digging in Burns. Ground should be frozen for the next 2 or 3 months and the days are pretty short.
  8. rhumbliner
    rhumbliner Member
    Jackson.Hole Las.Vegas
    Come Tesla! Let’s get that SuperCharger installed! Here’s a pic of 3 cars charging using: CHAdeMO, J-1772, and 14-50. Burns has enough traffic to justify a speedy install.
    • Like x 6
    • Informative x 5
  9. RocketMan88
    RocketMan88 Member
    Bend, OR
    worth noting... the permit expires in about 23 days. there were some recent doc uploads on it about 2 weeks ago but the docs are the same as the september doc uploads... which is odd
  10. Fadiawesome
    Fadiawesome Member
    IDAHO
    does anyone by any chance have an update on this? Did they break ground and start construction?
  11. 3'sterly
    3'sterly Member, RWD LR 3
    Bellingham Wa
    I’m sure mocial9 had this right back on Dec 6th because I was the person that had clicked “Print/View Summary” (2 times in early Dec).
    The Facebook gossip is heartening, but Plus EV is likely correct, this is “an odd time of year to start digging in Burns. Ground should be frozen... and the days are short.”
  12. painter
    painter Member
    I drove by at Christmas and pulled into the rite aid parking lot to look for any progress. Didn't see anything yet...
    • Informative x 3
  13. Tectonic
    Tectonic Member
    Colorado
    • Informative x 4
    • Funny x 2
  14. im.thatoneguy
    im.thatoneguy Member
    Seattle, WA
    Most of the Q1 locations have already broken ground. So I guess we can stop checking for a few months if even Tesla doesn't plan on any movement until at least March.
  15. t0ny7
    t0ny7 New Member
    Caldwell, ID
    It will be nice to have the Burns Supercharger. I went from Crescent City, CA to Caldwell, Idaho the other day. We went up through Bend, OR to Ontario, OR.
    We planned on stopping at Burns and use the J-1227 charger for a bit but someone was already there. My Model 3 said we could get to Ontario with 6% so we decided to on anyways. We went the speed limit most of the way but then had to drop down 5mph under and had the heat at 63F the whole time. Got there with 2% battery left. We had a good amount of range anxiety lol.
    Having Burns would make that trip far shorter and less stressful!
  16. PLUS EV
    Seattle
    That's definitely a sketchy crossing in winter. This is also why it's best to start off slow when crossing a charging desert, even if you do plan to top off along the way, you just never know if it will be functional and available.
  17. rhumbliner
    rhumbliner Member
    I’m assuming you don’t have a CHAdeMO adapter otherwise that would have been an option for you. And, there is a 14-50 receptacle there as well but it’s really only useful if you’re desperate — and I have been. We make the Jackson Hole to Bend trip fairly often so the CHAdeMO charger has been really nice.
    • Helpful x 2
