Supercharger cable a little on the short side?
Discussion in 'Model S: Battery & Charging' started by Asciidv, Feb 13, 2016.
  1. Asciidv
    Asciidv Member
    Ponteland, Northumberland, England
    Has anyone ever thought that the Supercharger cables are a little on the short side when you access them by reverse parking up to them? Fortunately the Supercharger that I use allows to me to side park as no-one else is ever there even though it has 8 bays.
  2. AWDtsla
    AWDtsla Active Member
    NE
    What was wrong with backing in properly?
  3. eye.surgeon
    eye.surgeon Active Member
    They're short for a reason. There's a ton of current flowing through those,they're very thick. longer=significant losses and weight.
  4. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Your SC makes it easy to back in with those tire stops on the tarmac, and your parking sensors and rear view camera make it simple. Why not utilize them? If you back in properly the cable will reach.
  5. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    I agree with the OP. I understand the high current and, as such, the need for a short cable but I think another 6" or so wouldn't be detrimental to the high current and would require less perfect parking for those of us who don't do everything exactly as required (without a couple of attempts). I think it's more the design of the stand, and how it fits in the holder as a perfect loop, that requires it to be so short.
  6. tstafford
    tstafford Supporting Member
    Nashville, TN
    Wife said the same thing after using several SCs on a solo road trip. Even six inches would help as Canuck says.
  7. jerry33
    Texas
    I've never had a problem in the 23 SCs that I've used. Some you need to back up over the stop rather than just have the stop at the bottom of the camera screen. Others, if you back up over them need to have the suspension lifted or they will scrape the bottom of the car when pulling out (those types never need to be backed over for the cable to reach.)
  8. deonb
    deonb Supporting Member
    Redmond, WA
    How are you supposed to know when driving up to a Supercharger whether you have to back up over the stop or not?
    It would be nice if Tesla would draw a line at the back of the Supercharger spot that says: "Stop here", and you align the camera up with that. They may need different color lines for S/X/3.
  9. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    Yeah, learn to park backwards......
  10. jerry33
    Texas
    Well, the way I do it is back up to where the stop is at the bottom of the screen and the cable will either connect or else I have to back up over the stop. I agree an indicator would be nice.
  11. Owner
    Owner Active Member
    San Francisco Bay Area
    I agree they are a little short for super easy parking. I've learned to really backup far. With the rear camera its easy. But my natural instinct is not to backup that far.
  12. ION eDRV
    ION eDRV Member
    Moorpark, CA.
    I never really think about it Kinda like putting on my shoes....
  13. Asciidv
    Asciidv Member
    Although using the reversing camera seems a fine idea, I think it has rained on all the 12 days that I have had the car, except for today when it was snowing. Dirty road spray water seems to hang from the lens so that only a out of focus blur is available. A washer/wiper on the camera lens would be top of my list as a must have accessory. Does the cold climate pack have this feature?
  14. jerry33
    Texas
    Unfortunately, no. It would be a very nice-to-have though.
  15. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    I, as usual, will voice my opinion.
    In GENERAL, the cables are good for Length.
    HOWEVER!!! In areas of poor weather (Specifically, snow & sleet), I find the cables to be too short. As winter progresses, especially during a winter where we do not get any days with warm ups, so no melts, the snow and ice does build up in the spaces. I find many of the locations do not get properly plowed or have proper snow removal (Spoke to one parking lot plow driver, he said he doesn't like to get close because he's afraid of hitting one of the stations).
    Heck, I've even seen stations (Angola) where most of the stalls were under the Plowed pile of snow.
    A extra 6 inches, or 1 ft, should not cause issues for the superchargers and the current involved, but can make the difference between getting close enough to plug in, or not. I specifically park like the OP did, if no one else is around, or if more then enough stalls are available, or if I can take a end space where I would not be blocking any other stations. Yes, if I block a station, I stay with the car in case someone else arrives.
    This is my experience after 80,000 miles, 3 absolutely crazy Wisconsin winters, and use of all 6 Wisconsin stations, and over 50 different stations used throughout the US and Canada.
  16. garygid
    garygid Member
    Laguna Hills, Orange County, CA
    The low profile tire stops help a lot, since one can safely back over them until the tire touches.
    Then, the rear of the car is usually within about 6 to 9 inches of the curb.
    If you are still finding the older high-profile tire stops, perhaps let Tesla know so that they can replace them.
    Snow removal is a considerable different issue. How does one handle that ... keep a snow shovel in the car?
  17. EdA
    EdA Model S P-2540
    Massachusetts
    It can certainly be challenging in snowy regions after a snowstorm.
    If you're the sole charger I see nothing wrong with the OP's parking job
    provided he stays with his car while charging.
