My wife just came home and I also verified that I cannot remove the charger cord from the Model 3 if I don't have my wife's phone with me. Pressing on the door handle causes the screen to light up with a message 'Tap key card to unlock' and does nothing to allow the charger plug to be removed. So as I said before to @Joshan, there must be something more going on that is allowing him to remove the charger plug, or there is something wrong with his car (or there is some setting which we are all overlooking).So you guys are freaking me out! I took my phone and made sure to place it out of Bluetooth range of the car and verified that as expected the car is still locked verified by trying to open the doors, charging is complete, and the charger cord cannot be removed. This is the way my early 2018 Model 3 has operated from day one.
Then just to be sure I came back with the phone now in Bluetooth range, opened the back door, and removed the charge cable. Maybe I'm not following but are some of you saying that with your Model 3 you are able to remove your charge cable (after charging complete) from a locked Model 3 without the phone or FOB in close proximity? If that is true that is bad.
ok, thanks, mystery solved. I still find this interesting. With my wife's iPhone, which when it's on the kitchen table is no more than 12 to 15 feet from her car in the garage, I still can't open the car or unplug the charging cable. What type of phone do you have?UPDATE: Someone earlier in the thread said this and they were correct. The Bluetooth distance to unplug your car and to unlock your doors is not the same. This is why I saw the behavior I was experiencing. As a test I just did the following:
- Went to my car with the phone and verified I could open the doors
- Plugged the car into the NEMA 14-50 charger
- Turned Bluetooth off on the phone
- I could not open the door & I could not unplug the car (expected as you all stated)
- I repeated steps 1 & 2 again
- I walked into my house in the kitchen about 150-200 feet away and set the phone down
- Went back to the car and could not open the car door
- I was able to unplug the car (as I had been experiencing)
This was the reason for the misunderstanding of the functionality.
Yeah, I'm surprised that BT would operate 150-200 feet away. In my case there's just a wood door between the kitchen table and my wife's model 3 in the garage 12 to 15 feet away.Whether you get a connection or not and at what distance is going to have more to do with the building materials in your house in the path between your phone and your car than anything else.
Giddings TX supercharger. It's not on the map yet. It's also free atm.
Wow....yeah wood should be good. If that's the direct path. I have a wooden door and can get data from my obd2 adapter right in my living room if I stand in a direct path but if I sit on the couch less than a foot back it won't work at all since the direct path will be two bricks walls at that point.Yeah, I'm surprised that BT would operate 150-200 feet away. In my case there's just a wood door between the kitchen table and my wife's model 3 in the garage 12 to 15 feet away.
The iPhone X has Bluetooth 5 which does have about 4 times the range:That's quite a house lol. Typo perhaps? Wrong units? Inches?
Typical BT range is maybe at max 30meters. Something amplifying the signal from the house to 150/200feet garage?
The Bluetooth 5 spec allows low-energy transmissions to sacrifice data rate for more range. A lot more range: up to four times the range of Bluetooth 4.2 LE, for a maximum of around 800 feet. That’s a theoretical maximum, mind you. In the real world, you can expect much less, though it’s still going to be a huge improvement over older versions of Bluetooth
Bluetooth 5 FAQ: Everything you need to know
It depends on the transmit power and lots of other factors. I have several devices that I can see from 300 feet away with Bluetooth.That's quite a house lol. Typo perhaps? Wrong units? Inches?
