Supercharger - Calallen, Texas
Discussion in 'Texas Supercharger locations' started by HillCountryFun, Sep 20, 2016.
Tags:
  1. HillCountryFun
    Texas Hill Country and Denver, CO
    All,
    Tesla just updated it's SuperCharger map to show an additional "Coming Soon" SuperCharger in South Texas. As you can see from this:
    The 2 grey locations South of San Antonio are coming soon. The top one is the new Three Rivers site which is totally built but not quite yet on-line. The lower one will likely be in Calallen, Robstown or somewhere close to Corpus. When the Three Rivers site showed up (about a month ago) on the Tesla map as coming soon we discovered that it was almost completely constructed. So, it's likely the new site is also well under construction! We should find it!!
    Happy Charging Everyone!
  2. SpiceWare
    SpiceWare Member
    Fresno, Texas
    Looking closer at the map, the pin's north of 37.
    Based on the pin position in relation to the bays, that's Sinton.
  3. HillCountryFun
    I agree, it does look like Sinton but I'm struggling with Tesla putting it there instead of on 37. If needed, we'll change the title of this thread when we find it!
  4. SpiceWare
    SpiceWare Member
    Fresno, Texas
    hmm. Houston, Victoria, Sinton, Kingsville, Lyford to get to the Space X launch site while towing something...
  5. SW2Fiddler
    SW2Fiddler I, for one, welcome our new Robot Axis overlords!
    Houston TX
    #5 SW2Fiddler, Sep 21, 2016
    This is just a cartography-based guess...
    Portland TX is at the closest longitude to the pictured Coming Soon pin (which lines up with pins for Perry OK and Wichita KS). On 181/35 there's a shopping center with an IHOP and Wal-Mart, and across the highway there are various hotels.
    73 miles from the Victoria TX SC and ~80 miles from Three Rivers.
  6. BerTX
    BerTX Supporting Member
    Texas/Washington
    Sinton seems unlikely. Are you assuming the location is actually located where the pin is? Look at all the other pins (like Sweetwater and Cisco) -- the pin floats well above the actual location of the Supercharger. You have to assume the location is much further south than the actual pin, in most cases.
  7. SpiceWare
    SpiceWare Member
    Fresno, Texas
    You can see he Three Rivers pin in my capture, it's directly on 37, though possibly north of the actual location. 37 travels in the same direction in that area, so I'd expect a pin for Calallen to "be off" the same way. Perhaps it's pointing at Odem.
  8. BerTX
    Texas/Washington
    My money is on Calallen, near the intersection of I37 and 77/I69. That's the only place that makes sense.
  9. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    The coming soon dots are a general vicinity. There not that accurate as to identify a specific location.
  10. Beryl
    Beryl Member
    South of Houston
    This is great news, This spot gets me to Brownsville from south of Houston. I may still stop an hour at the Dunkin Doughnuts in McAllen or even longer at that car wash in Brownsville but this SC will get me down there in under 8 hours. :)
    One more in Harlingen would be even better.
  11. Firewired
    Firewired Member
    San Antonio
    The Tesla Supercharger map now shows a Supercharger grey and opening soon in the Corpus Christi area. Anyone have ideas where it will be?
    Supercharger | Tesla
  12. SpiceWare
    SpiceWare Member
    Fresno, Texas
  13. HillCountryFun
    I agree with this location as well. Now that Three Rivers is open, anyone want to take a road trip and do some reconn? :)
  14. BerTX
    Texas/Washington
    We did go! But found no signs of construction, other than lots of road construction around the two hotels with Destination Chargers ar I-37 and Navigation Blvd. So much so that I wouldn't drive my month-old MS through the plowed-up loose gravel to get into the parking lot to check those out, although they are a little further south than I would expect the Supercharger to be.
    We looked primarily between those hotels and the intersection with I-37 with US 77 running north. There really isn't much there in the way of possible locations. The two that stood out to me is the Holiday Inn Express on US 77 (I-69) running south, and a shopping center parking lot near a Whataburger on the opposite side of the highway.
    The HI Express does not have a big lot, but there is a section that looks pretty unused adjacent to Brookhaven Dr.
    The section of the Shopping Center at the intersection with Northwest Blvd across the highway also looks unused, right on the access road. It is close to the Whataburger and other stores in the center.
    Obviously, there are other locations, these are just two that seem to fit the usual pattern. Or it could be somewhere completely different.
  15. HillCountryFun
    Thanks for giving it a great try BerTX!! I guess it's possible that it's not yet under construction but for the last few months it has seemed like "Coming Soon" means under construction. I hope we just haven't found it yet.
    We're almost a month since they added it to the Coming Soon map so it's possible that it could go live soon. I guess that's when we'll learn where it went!!
    Thanks again!
  16. Firewired
    Firewired Member
    San Antonio
    The supercharger.info site hasn't added it to their webpage either. I emailed them when I saw it on Tesla's supercharger map.
  17. Bet TSLA
    Bet TSLA Active Member
    Cupertino, CA
    Without a confirmed address, BlueShift considers it just a rumor. Hard experience with things appearing on Tesla's map but never actually materializing.
  18. Firewired
    Firewired Member
    San Antonio
    Ah, that explains it. Thanks.
  19. BerTX
    Texas/Washington
    #19 BerTX, Oct 17, 2016
    It is a surprisingly sparse area as far as development is concerned. Mostly industrial or just empty spaces.
    The Three Rivers Supercharger is nice, a Subway and McD in the Truckstop. I then went to the La Palmera Mall for a couple of hours of charging at the (somewhat weak) destination charger there (was meeting a friend for lunch), then went to the Victoria Supercharger. It's in a La Quinta, and there is a convenience store across the street. Spent the night visiting my brother in Goliad, then back home.
  20. ajn0914
    ajn0914 New Member
    Garden Ridge
    Tesla Super Charger spotted at Holiday Inn in Kingsville TX as I was coming home from South Padre Island (2400 S Hwy 77, Kingsville, TX 78363)
