Supercharger - Chico (Location speculation)
Discussion in 'California Supercharger locations' started by Blup85, Jun 18, 2018.
Tags:
  1. Blup85
    Blup85 Member
    Chico
    I can't say its location until they formally submit an application. The location has been finalized and I'd expect to see a permit soon (month?). Its in a great spot, with good access to sr99 and connections to sr32 for folks heading up to Lassen/Lake Almanor area. I probably won't use it all that much, but its comforting to know that if I forget to charge and needed to head out of town unexpectedly, I can grab a quick charge to get to Sacramento or head up the hill to the lake without charging at home for 3 hours!
    To be honest, I saw the 2018 date on the "Find Us" map for planned Tesla superchargers and thought no way we would have Chico's SuC by the end of the year, but this will be up and running before the fall! Cool to see Tesla hitting a planned date (even though its a wide 1 year window). A lot goes in to planning and installation of these stalls, like having to work with existing property owners, utility coordination, and the government.. .sheesh!
    When I have the green light to share I'll be posting as soon as I get it. Sorry about the click bait heading!
  2. PLUS EV
    PLUS EV Running on Empty
    Seattle
    Pardon my cynicism, but I'm going ALL IN on the OVER September 22nd opening date.
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Moderator note: thread title edited to remove acknowledged “click bait” wording.
  4. Blup85
    Blup85 Member
    Chico
    Took a little longer than I had hoped, but a permit has been accepted and under review for 14 Superchargers (expandable to 18) and 4 level 2 chargers at the Target Parking lot off 20th St. See attached. I'm backing off my absurd install date of being complete by this fall and hoping for the end of the year.
  5. ecarfan
    San Mateo, CA
    I see a Google Maps aerial photo but don’t see a link to the permit.
    Tesla’s Find Us page still optimistically shows this location as being operational by the end of 2018.
  6. Blup85
    Blup85 Member
    Chico
    huh.. it works for about 5 minutes then the link is broken...
    Look up Permit # 18-02934
  7. McManX
    McManX Member
    San Francisco, CA
  8. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    Slightly closer spacing between Vacaville and Chico (107 miles) than Vacaville and Corning (113 miles) but slower travel. Obviously more useful if coming through Sacramento (82 miles), and only if you're towing or have some other restriction on range.
  9. PLUS EV
    Seattle
    I think it's mostly just to build out 99 north of Sac. It's a fairly major highway.
  10. EV-lutioin
    EV-lutioin Active Member
    Yippy, a Supercharger in my hometown! Not that I will ever need it, but still pretty darn cool.
  11. Blup85
    Blup85 Member
    Chico
    From what I can tell, they haven't added any stalls that would allow a trailer to pull directly into a stall. Bummer because I could see using this to top off for the climb up to Lassen when towing.
  12. ohmman
    North Bay, CA
    It was my first thought, as I currently go through Corning for that. But pull through isn’t necessary. Unhitching isn’t terribly time consuming or difficult. I’ve become quite quick at it for Supercharger stops.
  13. ecarfan
    San Mateo, CA
    Agreed, unhitching/hitching at Superchargers is much less of a hassle than I anticipated it would be. It’s even easier for me than it is for @ohmman since I don’t use weight distribution bars. And I just installed an electric tongue jack which can raise/lower my trailer tongue even faster than I can hand crank it. I think I can unhitch in about a minute, and hitch up in less than two minutes if my first attempt at backing up to position the hitch ball under the tongue is successful.
    Since I don’t live in Sacramento I don’t anticipate using the Chico Supercharger, but I can’t rule it out.
    The future Redding Supercharger could be helpful to you.
  14. mattcrowley
    mattcrowley Member
    Los Altos, CA
  15. cpa
    cpa Active Member
    Central Valley
    Yes, but SR99 through the Sacramento Valley is much prettier than Interstate 5 with fewer semis on the road. Moreover, during the summer months there are ample locations along 99 to grab some tasty produce at the roadside stands for fresh eating during our trips.
    Chico to Susanville (and its anticipated Supercharger sometime in the 21st Century) is 100 miles. Northeast on highway 32 and then east on highway 36 over Fredonyer Pass is the route. I do not know if the elevation gain to Fredonyer Pass (5750 feet) from Chico (200 feet) is too much for a Model X with trailer in tow to surmount and arrive in Susanville without hypermiling up highway 32. It is all downhill to Susanville, and I guess the distance to be about 15-20 miles.
