Supercharger - Fairfield, CA - 3001 Travis Blvd (LIVE 1 Mar 2023, 12 V3 stalls)
Its finally open!
Wish they'd open the new Dublin one already, just been idle for months and months
I was here yesterday checking out the new SpC and that security station is TOTALLY in the way of parking and driving. They should move it onto the muddy grass, I had to do a 9 point turn to get into the supercharging space.
Reactions: jboy210
Or another way is to come into the lot from the other entrance down the street, where the not-yet-operational EVgo chargers are. I only discovered that when I was leaving but apparently some other owners were smarter than us and figured it out earlier.
Bruce.
Reactions: israndy
Any idea why the switchgear cabinet is so large? Typically it’s just one cabinet about the size of a charging cabinet. This one and the one in Napa (it’s green there though) are 3 times the size.
It’s probably a 4000 A cabinet. Those cabinets match the capacity of the largest 480 V transformers that PG&E is using (3325 kVA). Any future expansion would only need a transformer change out on the utility side as the bus bar size and ducts would already be sized to that larger cabinet. A pad mounted transformer change out is mostly a bolt on affair.
Reactions: sunnnv
Do they bill by the transformer? Why not put in a bigger one if you plan to expand?
Yes. PG&E charges less money to provide and connect a 1000 kVA transformer like they have now versus a bigger 3325 kVA transformer. I don’t know the rationale of Tesla not asking PG&E for the bigger service from the get go: perhaps they have no set plans for expansion yet but want to lay the bigger switchgear and cables to avoid having to dig in the future if they do.
Reactions: sunnnv
Where would said expansion go? That side lot is full.
I am guessing there is something else going on. Maybe the ability to feed back into the grid from a solar canopy or something? Or room for small battery storage to shave peak loads? If they wanted to plan a future expansion they would have put it someplace where additional stalls are feasible in the same area.
