Supercharger - Fort Bragg, CA (LIVE 21 May 2021, 12 stalls)
Mar 11, 2010
4,537
1,403
Humboldt/Los Altos
The permit doesn’t show up in the list of approved permits for Jan or Feb 2021 so it must have been approved first part of March. Be interesting to see the approved comment line to see if it still lists 12 stalls. Equipment on site sounds like it points that direction and the outline on the map looks like the fence is encompassing enough space for 12 stalls.
If it is 3 V3 cabinets that would make sense. 4 chargers per cabinet.
sick setups compared to the V1 stuff!
nikh
New Member
Mar 31, 2021
I stopped by here to check in on the progress last weekend (3/27) and it looks like all of the equipment is gone? All that’s left is that big pile of conduit, and it didn’t look like any actual digging happened.
goldengate
389
460
san rafael,ca
Let me guess... one of the shopping center tenants complained to management about losing parking spaces in an already small lot?
I don't recall ever seeing a supercharger started and erased this way?
Mrbrock
795
477
Napa, CA
In about a week the updated permit status document will be published so we should see it as approved on there. The applicant listed on the original shows Tesla and the owner of the shopping center so I would assume they would have oked with tenants but who knows. Maybe the permit wasn’t actually approved and county issued a stop work order?
Mar 11, 2010
4,537
1,403
Humboldt/Los Altos
wow, that really sucks! that's quite a bit of stuff to take a way. they had a contractors office and just about everything needed for the project there!
coastal commission maybe? that is a pretty tight parking lot, I could see complaints from someone
Mrbrock
795
477
Napa, CA
If the permit approval shows up, that means it was properly vetted unless the county/city skipped something. Complaints are due during the comment period between when the permit is applied for and when it is approved. Coming in after is just being lazy.
goldengate
389
460
san rafael,ca
If you look at the google satellite view, almost every space of the parking lot is full... and that's before a supercharger takes 12 of them. I am guessing one or more tenants complained about losing spots in a small parking lot, and as much as I would like to have a supercharger in Ft. Bragg, I can't blame them.
Mrbrock
795
477
Napa, CA
Looking at the Jan/Feb docs those were posted on the 1sr or 2nd of the month so maybe Monday we will see the March ones. Maybe some more insight into this. If it doesn’t show up as approved maybe Tesla jumped the gun and the county shut them down.
Hopefully the center owner contacted his tenants before signing a lease with Tesla for the spaces. Also, I am not familiar with commercial leases but is it standard for tenants to be able to demand parking spaces? Seems like the owner can do what they want and a specific tenants lease wouldn’t dictate the number of spots required for their business.
May 2, 2018
63
89
I've had two leases in strip malls. One gave me a specific number of parking spaces (not that it made any difference -- customers will park where they want) and the other did not. The more square footage you lease and the more financially solid your business is (e.g. you're going to be able to afford the rent for a while) and the more vacancies in the area, the more demands you can make on the landlord. It's not unusual for different tenants in the same strip mall to have different leases.
Mrbrock
795
477
Napa, CA
So in this case, if in fact it was tenants complaining ning, the landlord agreed to something without looking at his leases? Seems like bad business to have every spot allocated in a center.
Mrbrock
795
477
Napa, CA
So after doing a little more digging there is an eTRAKiT site for Mendocino. Here is a grab of the permit which shows it as approved 1/22/21 and issued 3/18/21 which coincides with the pictures posted here on 3/19. Still have to figure out why all traces were removed shortly thereafter. Look at reviews it shows one last week that was approved so maybe they found something at the initial site inspection that caused the. To resubmit something? Anyone from the area have any dirt? Maybe someone can swing by and see if this latest review has led to more construction. If I find anything in the local news sites I’ll let you know.
goldengate
389
460
san rafael,ca
Good work @Mrbrock! I couldn't find the permit with the address but was able to search using the permit number and it came up, so thank you. I would say this is good news... it went back to planning last week and Richard Angley who did the original plan check back in January turned around the plan re-check in one day. That means to me it wasn't a tenant complaining but instead something they found once they got on site that required a minor plan revision and a resubmit. Now that the resubmit has been approved, I would think construction should start back up again soon. When this got delayed I switched my Mendocino trip to Carmel (that's how important superchargers are to tourism, if you're listening towns!) so won't be able to snap photos up there but hope someone else is nearby and can run over. Thanks again. While only 12 stalls, this supercharger fills a major gap in the network and will open the coast back up to me and many others who don't want to depend on destination charging.
Mrbrock
795
477
Napa, CA
Yep, nothing about a dispute on the local news sites so likely a resubmittal. Interesting that they took all the equipment away though unless it was needed somewhere else.
101 boatyard for the address will show you all the permits for the center including 2020-0756 and 2018-0414 for a ChargePoint installation. It’s only one spot but it does establish the center can “sacrifice” parking for charging.
Reactions: goldengate
