I'll have to look for the thread. Guessing demand charges.it's not the pairing... it's the reduced charging rate at superchargers in California since summer started... you probably need to check out that thread if you don't understand
Please explain what you mean by that, I don't understand.Guessing demand charges.
That's design.. Folks need to understand that. It's up to more experienced drivers to train others about pairing and sharing.
(at least until Tesla is able to upgrade each stall from the need to pair)
1) It's great to know about reduced charging rate due to pairing and sharing but when you talk about 8 bays that were all full with another 11 cars waiting in line, I don't know how that knowledge is helpful in this case.
2) It's great to know to know about that design but it is flawed if the goal is to reduce the charging time when the station is busy with 11 cars behind.
It is helpful because the second person to join the pair will understand that their charging rate will be less than expected and will speed up when the person that they're paired with leaves and they become primary.
That's where it helps.
I think I understand how knowledge in this case would give you a consolation prize that OK although you are 11th person in line, soon, you'll be paired up at a reduced rate, and eventually, your rate would be increased when the other paired bay would become vacant and immediately be paired up again.
A better solution would be faster charging rate, no rate reduction when pairing up, and more charging bays. That would increase the turn over rate and cut the waiting time for the other 11 cars in line.
...There have been reports of the Newark, DE Supercharger is designed to run independent and no pairing...
I'm not saying that expanding the network and faster charging stalls is NOT the ideal solution. There have been reports of the Newark, DE Supercharger is designed to run independent and no pairing. That IS a better solution. However, the reality of the situation is FV is congested and hopefully getting Buena Park and Santa Ana will alleviate this congestion. Perhaps Tesla will re-jigger so that there won't need to be any pairing in the future. However, the facts are what they are.
Where are these reports of no pairing?
It seems unlikely that Tesla will take that approach, at least until/unless the number of available spaces becomes a bigger limitation than either the power available or the cost of installation.
Twelve full power stations is better than twelve shared stations, certainly - but wouldn't twenty four shared stations be better yet? It wouldn't cost much more...
Yes, but the demand charges under (2) are somewhat punitive, so it is definitely very much in the consumer's best interest to decrease their maximum demand. Enough so that at the company I worked at, they would sometimes run their backup co-gen turbine on hot days to smooth their peak load.Since I work for the local utility in San Diego, I can help clear up the questions related to demand charges. In very general terms, there are a couple of different methodologies that are used for billing commercial customers.
1) A rate where smaller customers pay (for the most part) a simple price per kWh. The threshold for staying on this rate is that your maximum demand for the month must stay under 20 kW (at least in our area). There is a small TOU signal with this rate, but not much.
2) A rate where larger commercial customers with demands over 20 kW (for the most part) pay a less expensive price per kWh (about 1/3 to 1/2 of the price above depending on TOU consumption). But in addition to that lower price for the energy, there is another billing component called a demand charge that is tied to their highest kW demand at two different times in the monthly billing period (coincident with the power system peak, and not coincident with the power system peak). The demand charge is then calculated and billed at a rate that aligns with their maximum kW demand per month.
I've seen incorrect references that demand charges "kick in" at a certain level, etc. and that is not true. You are either on the (1) rate above or the (2) rate. If you're on the (2) rate, then demand charges are in play every month with every bill.
However, having said that, it is still advantageous for a SC site to be on the (2) rate above with demand charges because it works out to be cheaper overall (due to the cheaper price per kWh for energy dominating the calculation that includes the demand charges).
Probably too much information, but it felt that some explanation would help out the discussion....
Whatever times CostCo isn't open. :-/I'm visiting from Northern Cal this week. where I'm staying has no ev charging on site, which kinda sucks as I'm used to plugging in at home at night. So question is, what is the best time to charge where crowds are minimal? After 10pm? Before 7am? Trying to optimize my charging time to avoid the waits.
Before 9am, after 9pmI'm visiting from Northern Cal this week. where I'm staying has no ev charging on site, which kinda sucks as I'm used to plugging in at home at night. So question is, what is the best time to charge where crowds are minimal? After 10pm? Before 7am? Trying to optimize my charging time to avoid the waits.
I am curious to see if there has been any improvement at this site given the recent addition of idle fees. Can anyone here comment on this?
