Supercharger - Georgetown, TX
Discussion in 'Texas Supercharger locations' started by mociaf9, Aug 11, 2020.
  1. mociaf9
    mociaf9 Active Member
    • Informative x 11
    • Like x 4
  2. DriverOne
    DriverOne Supporting Member
    Austin, TX
    Sounds awesome... how'd you know this is an SC and not a wall charger? It'd be a wonderful SC location for those driving I-35 or 130.
    Otherwise its full stop ahead in Texas :( All that lovely hill country & Big Bend, unreachable (or at least difficult & slow).
  3. Electroman
    Electroman Supporting Member
    TX
    Temple, TX would be a better choice. But I will take anything.
  4. mociaf9
    First the application was made by GPD Group which is the engineering consultancy firm Tesla currently uses for the majority of their US supercharger deployment. Second is the suitability of the location. It's right off I-35 in a large shopping center that looks like a very good fit for a supercharger. Plus, there's a Target store there and Target is one of Tesla's big partners when it comes to businesses hosting superchargers at multiple locations. If Target actually does turn out to be the host, then the site will almost certainly also include a few Chargepoint L2 stations as this seems to be a feature of the Tesla-Target hosting agreement.
    I admit this reasoning is not totally definitive but, as someone who has a pretty good track record for finding supercharger stations in pre-construction phases of development, my assessment is that it's overwhelmingly likely that this is for a supercharger.
    • Like x 4
  5. Twiglett
    Twiglett Single pedal driver
    Austin
    The location you put as the coordinate guess was 1031, not 1013.
    1013 is the address for the block behind Panda Express and Buffalo Wild Wings with Specs and various restaurant or other food type places.
    The whole Wolf Ranch location doesn't really have any areas that don't get crazy busy.
    If it really is here it will be constantly ICE-ed.
  6. mociaf9
    Addressing for these sites isn't often that particular. I placed my GPS guess by assuming it would be in the portion of the complex that could be considered Target's parking lot and then looked for what looked like the least desirable areas in that lot. I may end up being totally off. Have to wait and see.
  7. HRP783
    HRP783 New Member
    Austin TX
    I own a business near by, I’ll keep an eye out and post pics
  8. brkaus
    brkaus Well-Known Member
    Austin, TX
    That's fantastic for trips from Dallas to far SW Austin!
  9. g1ant405
    g1ant405 New Member
    Round Rock
    • Informative x 2
  10. N13MS
    N13MS Member
    San Diego
    Excellent news! Hopefully V3.
  11. scottyaggie
    scottyaggie Member
    Dallas, TX
    Definitely not unreachable. I've made several trips. Check plugshare.com for chargers in Kerville and Terlingua.
  12. SilverString
    SilverString Member
    Bee Cave, Texas
    I'm all for more superchargers and Dallas to Austin will be pretty well covered all the way up to Denton on I-35. Alvarado, Waco, now Georgetown will be great, relieving the stress on the Waco and the Austin 290/I-35 superchargers - both those are always busy.
  13. mociaf9
    Excellent, thanks for sharing. Now we can fill in a bit more information on the specifics of this station. It's currently being proposed as 16 V3 stalls. And @Twiglett was right that they were using a more precise street address, with the exact location in the NE corner of the lot between McAlister's Deli and Longhorn Steakhouse/Panda Express. Updated GPS: 30.632093, -97.694003 (map link)
    • Informative x 2
  14. Twiglett
    Austin
    interesting info, thank you.
    I didn't realize the V3 meant one cabinet to four stalls.
    I think I'm reading it right that each cabinet is about 300kW, which mean we have to spread out every four instead of every two.
    So if all four stalls are in use for a given cabinet, does that mean 75kW each?
    I've not been to a V3 before so I don't know if they label them as 1ABCD, 2ABCD etc
  15. mociaf9
    Each cabinet can individually draw 350 kVA AC from the transformer, but the cabinets are all connected to each other across a DC bus and share power that way, too (max DC input is 575 kW). The max output for a single cabinet is therefore closer to 900 kW, which would give +- 225 kW per stall assuming you could engineer a situation where you had 4 cars connected to a single cabinet trying to pull that much simultaneously (and enough additional cabinets to provide the full power). The idea behind this architecture is that there's no need to care which stall you use, they effectively don't share power the same way that the V2 stalls do. So, plug in to whichever stall catches your fancy.
    Mostly it seems that Tesla hasn't been labeling the stalls, but in the instances where they have, yes it's 1ABCD, 2ABCD, ... The markings aren't in the same place, though. They are smaller and much less noticeable, usually placed on the information sticker on the inside ring of the supercharger pedestal (i.e. the red part) where the support phone number is.
  16. StoicKiwi
    StoicKiwi Member
    San Antonio, TX
    This is some fantastic news! Coming to or from San Antonio along I-35 has been rather annoying since there were no SuperChargers on the toll road. We always have to drive straight through Austin into the crazy traffic and typically stop there for our final charge (not to mention the Austin SC is very busy).
    With this Georgetown SC, you could finally take the toll road nearly to the end and charge up!
  17. N13MS
    N13MS Member
    San Diego
    Drove through the Target lot today (and over by McAlister’s) and no sign of construction just yet. My best guess is it will be in the NE corner of the Target parking lot. There are a ton of restaurants within walking distance. Will be a perfect location.
  18. brkaus
    Austin, TX
    the map within the presentation in post #9 shows the exact location. Bummer nothing has started yet. Please keep us updated if you frequent the area.
  19. XHabjab
    XHabjab Helping to end the ICE Age
    Georgetown TX
    I'd say pretty good but not perfect. The daytime choices are good to excellent but I can't think of anything in the area that is 24 hour. My bladder works around the clock.
  20. Twiglett
    Austin
    its not in the target parking lot, its over by Panda Express, Longhorn Steakhouse, between them and Specs/Souper Salad etc
