Correct. I routinely get 105-110 KW initially, a couple of times 114-115 KW. 2015 70D.I think the real 70kW packs can charge faster. (But I'm not positive.)
The new chemistry gave slightly better energy density: went from 85 to 90kWh with same amount of cells (and 70kWh went to 75kWh). The trade off is silicon anodes tend to have slightly worse cycle life (they also charge more slowly). Tesla used partial silicon (instead of full) to try to mitigate the trade-offs, but they will still be there.I'm wondering how the new design or cells or whatever have any real-world improvement at all over the older ones.
The old 70 batteries could do that (118kW) but the new 70 batteries (locked 75) can do 100 max.I simply disagree with this mythical 100kw max for smaller packs. I have 70s and routinely on trips run it to 0 miles range left. It always churches at 110-119 KW until it starts tapering. Some chargers I have found maintain higher KW than others. As I always make the same trip to Orlando I know which chargers are usually slow and which ones are faster.
I have an original 70. It is 350 volts.sounds like the original 70s were 400 V cells.
I stopped at Burlington, WA, twice this weekend, along with Squamish, BC, once with my MS 75, nee 60, and was getting ~38 kW consistently at both (about ~90-100 A, ~385-400V). (Nobody paired with me; almost all slots empty. Charging from low or mid-levels, which made no difference to the rate.) Perhaps those are actually slower older chargers with lower limits, but that still seems low.
It pretty much kept up at that rate even up to 90% and above, which is consistent with a low charge rate. Temperates were moderate (upper 70s to mid 80s).
Yesterday my wife was at the Sandy, OR Supercharger and was only getting mid 40kW at a 50% SoC (I normally average 70-80kW at this SoC). Only one other car there and on a different pair. MS75 with 11k miles and only a handful of Supercharges done, so it should be nowhere near the limit. My previous 2013 MS60 had way more charging done and wasn't nearly that slow, even with a smaller battery! I just assumed it was throttled because it was hot out and she was sitting in the car with the AC on. The car also uses the AC to cool the batteries during fast charging, so I assumed it throttled due to having to split the AC load. Now I'm a bit concerned that may not be the case and something else is going on here. Maybe that's the reason for the latest firmware upgrade that just came out?
I'll be going to Whistler, BC this weekend, so I'll be testing at 3 more locations. Hopefully this will resolve itself. But if it continues to happen at other locations, I'll be calling Tesla as well.
As I pointed out earlier, I did that on each SC on my 2500 miles trip. On the second charger I switched to, it would go higher (as high as 98kw) for a few minutes and then go down again to around 50kw. Even on SOC's in the 20-40% range.Both of these seem like a scenario covered by basic troubleshooting steps. When this happens, you should move to a different spot. This is very likely the charger getting stuck in the balancing mode (acting like there's still another car at the other pair).
That's the problem with thread like this. The OP specifically said he did not want to discuss basic troubleshooting steps, but people are drawn here for basic scenarios that such steps would cover. The counter discuss targets the peak charge speed, and doesn't bring it down that low (definitely not half speed as reported in these instances).
Yes, but the difference is they didn't try a different stall to see if speeds are bumped up, so it's impossible to tell.As I pointed out earlier, I did that on each SC on my 2500 miles trip. On the second charger I switched to, it would go higher (as high as 98kw) for a few minutes and then go down again to around 50kw. Even on SOC's in the 20-40% range.
Now I'm definitely going to look hard at the Bolt for her and may not go with another Tesla if other companies can reach parity in performance, range, and styling
I take delivery of my S 90D next week. What doesn't make sense to me is that with all of this talk about SC overcrowding, why would they purposely make the charging process take longer than it should? You'd think their incentive would be to get people in and out as quickly as possible... and if they're as careless of the owners as some in this forum think they are, they wouldn't care about long-term battery damage by overcharging. There are just too many conflicting stories that I'm seeing... I'm not doubting anyone, but it's the motives and circumstances I'm questioning.
I have a SC halfway between work and home and originally intended to stop at a SC like I would a gas station.... I mean, I've got "free unlimited Supercharging", and I don't see any reason why I wouldn't use it as such.
FWIW, I experienced similiar in a P90D recently in Georgia and Florida. I opened a case and was told the superchargers that I happened to use were running in degraded mode. It wasn't my car. I didn't get any more details; if it was heat related (the SpC cabinets also have thermal protections, just like the battery packs), maintenance issue, or a peak power limit (this has happened in Cali).
NC, SC, and Virginia were all fine. What was particularly strange was that peak power would initially climb near the expected range but then drop back down after 30 seconds. This made me think is was a thermal issue.
I think you're assuming tesla is throttling to be punative somehow. That's not the case. Tesla is throttling to protect the longevity and capacity of the battery packs. Of course they want people to charge as quickly as possible. It would save them a ton of money in infrastructure not to mention make a better product.
That's the problem with threads like this. The OP specifically said he did not want to discuss basic troubleshooting steps, but people are drawn here for basic scenarios that such steps would cover.
The counter discussed targets the peak charge speed, and doesn't bring it down that low (definitely not half speed as reported in these instances).
Yet it can charge at 115 kW.
That means that it would draw about 330 amps.
Anyone know if this is accurate?
