Supercharger - Grand Forks ND
Discussion in 'Midwest/Great Lakes' started by aus1ander, Jul 17, 2019.
  1. Manitoba Keith
    Brandon, Manitoba
    A few weeks ago (possibly last weekend), I was making the trip north from Fargo and when I got to Grand Forks, it was about -20f (-28C) if I recall correctly.
    Is there a special reason they can't do construction?
    We used to work, pulling wire & doing other electrical work, outside in -30C temperatures. No, we did not enjoy it, but it got done.
    Now they have tents and heaters. Besides, the weather is getting so nice now, almost spring like.
  2. meanwhileinND
    meanwhileinND Member
    Grand Forks, ND
    IMG_0841.jpg K2
  3. meanwhileinND
    Grand Forks, ND
    Ya they could do it. If they had to.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    I suspect that they planned for spring so that they won't have to worry about storm or other weather delays. There are a bunch of Superchargers there to work through.
  5. PLUS EV
    PLUS EV Running on Empty
    Seattle
    Yeah North Dakota never has storms in the spring :D
  6. meanwhileinND
    Grand Forks, ND
  7. MD-2000
    MD-2000 Member
    Winnipeg
    I depends on snowfall. I haven't heard of any big dumps recently, since I took the photo a month ago. (But then, ND weather is not high on my watch list). You can see on my last photo (Post #30) about a month ago, the pile was probably 10 to 12 feet. It's not going anywhere until spring, unless they get energetic about snow removal. I doubt that it would be specifically moved for SC construction, as mentioned there are plenty of other sites across ND better prepared - just need pulling cables and installing hardware. Fargo, Jamestown, Bismark, Dickinson... A week or two at each takes the crew into April before they have to worry about Grand Forks, and completes a route.
    Other than the fun of working making connections in sub-zero temps, which can be alleviated with heated tents, another issue is that AFAIK wires become stiffer in cold weather, something less that fun when working with curved conduits and very thick wires.
  8. meanwhileinND
    Grand Forks, ND
  9. meanwhileinND
    Grand Forks, ND
    IMG_1144.jpg Easter snowpile.
  10. MD-2000
    MD-2000 Member
    Winnipeg
    Hmmm... that snow pile is going down. It should be washed away in a month or so...
  11. meanwhileinND
    Grand Forks, ND
  12. EV3_
    EV3_ Member
    Wisconsin
    Aaaah! Spring in North Dakota!
    • Funny x 2
  13. MD-2000
    MD-2000 Member
    Winnipeg
    When it's spring in northern Canada, the ice is warm to the touch... :)
    • Funny x 2
  14. meanwhileinND
    Grand Forks, ND
    Update as of 5-14-2020. No Activity at the GF site. But at least the snows gone.:)
  15. MD-2000
    MD-2000 Member
    Winnipeg
    I wonder if this is next when Jamestown is done? Jamestown appears to have had their hardware delivered at the same time construction started, but most of the TransCanada last year and several other sites around this area, the ground prep conduits and bases were done well before the charging hardware arrived. ,
  16. VIKING26
    VIKING26 Member
    Fargo
    I wouldn't be surprised if I-94 in North Dakota is turned on in the next month or so and Grand Forks and Pembina are pushed to next year or later. Which really sucks for those needing to go North/South in this area of the world.
  17. DigAdrenaline
    DigAdrenaline Member
    Canada
    The Fargo thread says I94 should be this week, actually.
  18. MD-2000
    MD-2000 Member
    Winnipeg
    #58 MD-2000, May 22, 2020
    There are L2 chargers in Morris (Tim Hortons) and Grand Forks (3 of them) which should make this trip easily do-able in warm weather.
    Anything more on the Hillsboro L3 charger planned?
    When we were in GF in January, besides admiring the snow pile, I was trying to figure out where the power feed would come from for that location indicated on the map. It seems it would require a fairly long feed from the road on the other side of TireOne. maybe utility side of the job is now delayed...
  19. meanwhileinND
    Grand Forks, ND
    Solar powered with a giga battery would be cool!
  20. EV3_
    EV3_ Member
    Wisconsin
    At least Fargo is up now. A lot more options now. Would love for something to happen here!
