Supercharger - Hillsboro, OR
CWhite
28
32
Beaverton OR
Finally showing the correct status of the chargers on the app and in-car nav.
adiggs
4,177
11,401
Portland, OR
Been awhile since this thread has been updated - my wife and I have pretty regularly seeing something like 60 or 70kw charging as the max at this location. We've done enough supercharging at other locations (often the drive to Bellingham from Portland) that we know when we're clicking along at 'normal' and when there is something off with the charge rate.
Our Model X from 2017 is more limited in it's charging rate - I think 130ish kw is our typical limit. But we're seeing roughly 1/2 speed when we stop here, even when the battery starts off pretty low and should ramp much higher - at least to 110kw.
Are others seeing 1/2 speed, or similarly degraded, charging performance still at this location?
CWhite
28
32
Beaverton OR
A post in Nov showed a Model 3 getting 198kw. In my 2020 Model S at this station I have seen 130kw one time(20% SOC and a not fully warmed battery). And another time 24kw (75% SOC and 45° battery). If you set your nav your battery will precondition to warm itself up to help charging. Temperature makes a big difference. I am waiting for spring to see how it changes.
PLUS EV
Running on Empty
Sep 16, 2016
5,805
8,547
Seattle
If you're only driving from Portland to Hillsboro in winter, your battery will be too cold to get your max charge rate. I'm not saying that's for sure what's going on, but it's a strong possibility.
adiggs
4,177
11,401
Portland, OR
I'm confident that it's not a cold battery - I've seen that dynamic, and I've seen the charging station refuse to budge off of 50-60kw charging rate, even when it's been there long enough to have warmed up. I do know that can happen.
It might be special for us Model X/S owners, but I routinely clear 110 kw at other superchargers - both the newer and the older.
Absent anybody else seeing something similar I suppose I'll put it down to cold battery. It's certainly the right time of the year for that.
Doanster1
843
454
Oregon
In a previous post a page or so up, I saw 120kW for a short time when arriving with a fully warmed battery and ~10% SoC. This was back in December. This is with a P85D. Haven’t heard of others I know who’ve used this site say they saw 60-70kW right off the bat like you (unless SoC was already high and/or confirmed cold batt like they live a mile away or something).
chrstna4
175
233
Seattle
I heard on Out of Spec Motoring a hypothesis that 250kw chargers can’t give 250kw to all 4 units at the same time. He said he would try to test it but I haven’t seen the result. I was there with all chargers full, fully warmed battery, low SOC (Model 3) and got 120-145kw over the weekend.
Araman0
259
378
Seattle
A feature request that would be simple for Tesla to implement would be a one-liner on the display indicating the reason for a significantly slowed charge rate.
Reactions: Rocky_H
mtf16
45
141
Oregon
It is very clear that a single V3 cabinet with 4 stalls won't be able to deliver 4 250kW at the same time, as the maximum AC input to a cabinet is 350kVA. In a station with multiple cabinets, they have the potential to deliver more as the cabinets can share DC power among them up to 575kW. That basically says 4 stalls from one cabinet can never deliver 4x 250kW at the same time.
How much total power can be delivered at the same time at a station is pretty much determined by the main AC circuit the site is set up for.
superchargerplate2-jpg.32644
