Anyone else think it's odd that the tap wires leading down to the SC transformer are much thicker than the overhead distribution wires?
Perhaps it is just thicker insulation because they are no longer out of reach.
Well, the first thing I was taught about rock climbing was "learn to trust your equipment, then it gets a lot easier." The same rule might apply here.It's always amazing to me that they make the last connections to the overhead wires while the line is hot. You have to trust your insulated lift and have the right tools...
Actually, there's a lot going on in that picture I don't understand (but I know nothing about HV distribution). It was much more complicated than I expected (I was expecting to see three pieces of wire connecting the stripped ends of the insulated wires to the overhead lines, not all the crap noted below).
Now that you mention it, I was surprised at how thick the wire was on the trailer-mounted spool I saw last week: Supercharger - Hooksett NH Rest Areas - Page 18They appear thicker, because they are "coaxial", the center conductor is the same size, surounded by an insulator, then there is an overall aluminum shield to keep RF radiation down, which is grounded.
So the three "insulators" next to the splices that have power going into the top and ground out the bottom are the lightning arrestors. I get it; that makes sense now. I just noticed that there appears to be a wire running from the horizontal ground to the guy wire (which, I'm guessing, is part of the grounding system).Each of the 3 conductors in the 3 phase wiring is connected to a lightning arrestor, as well as the center coaxial conductor of the leads running into the conduit to the transformer. The bottom of the lighting arrestor is connected to ground, as is the coaxial shield on the 3 wires going to the distribution transformer. The grounding is to keep RF radiation down.. which is does very well. It's actually not all that complex, once you are aware of the lighting arrestors, and that the shields of the coaxial HV conductors are also grounded. The bottom wire running along that pole is an earth ground, as you can see it connected to the bottom of the lightning arrestors, and it also connects to the coaxial shields on the 3 down leads to the dist. transformer.
Although I'm surprised that RF filtering is needed, given this is only 60Hz AC. What's the source of the RF?
How about a gathering celebration at HOOKSETT NORTHBOUND this Saturday? I'm thinking 1 to 2 PM to give Vermont owners time to get down there. I'm going to talk to Tesla this morning to see if they can send someone up from Natick.
Anyone interested?
Todd Lockwood
Burlington, VT
Anyone interested?
Todd Lockwood
Burlington, VT
Actually, a two-hour window probably would make more sense: 1 to 3 PM. The weather looks ok. 90% chance of light rain & snow in Hooksett, with a high of 38F. There's 0% chance of precipitation for White River Junction VT, so this should not be a big problem for those coming from the north.
KEEP AN EYE on this thread for updates.
EVENT TO BE RESCHEDULED FOR APRIL
Due to the short notice, the majority of owners I contacted had prior plans for this Saturday. And of course the weather could be a problem for those coming up from points south. So we're going to postpone until April. The good news is that Tesla is interested in making this an official Tesla event! Perhaps we'll get both Northbound and Southbound locations involved. Tesla will be contacting owners in the region once it's on the calendar. Should be fun!
I should be able to be there, P85D is scheduled to be delivered in March.
