Supercharger is ramping down the Amps delivered
Discussion in 'Model S: Battery & Charging' started by Seth, Feb 16, 2014.
  1. Seth
    Seth Member
    DC-FL-CO
    Sitting in my car at my first ever supercharger visit (Ft Myers) and I'm pretty disappointed. I took a picture when it was pumping at 120a but now it's down below 100! It started at 240 and has been steadily dropping.
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Welcome to TMC!
    That is completely normal. You are close to full so it starts ramping down fairly quickly.
    See
    Supercharger | Tesla Motors
    under 'How it works'
  3. DavidM
    DavidM P2624, Delivered
    Florida
    Seth, Your screen shows you are at 207 miles of range. The supercharger tails off significantly when you are nearly full. If you rolled into the supercharger with 50 miles of range, you would be very impressed. I charged at the Ft. myers supercharger yesterday before the meetup. I rolled in with 115 miles of range and added roughly 60 miles of range in about 12 minutes.
  4. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    This is totally normal. Wait until your get close to 100% charge and your current ramps down to 6A... :)
  5. Cottonwood
    Colorado
    As others have said, completely normal. This graph is from the Tesla Supercharger page:
    As you can see the rate of charging decreases as the State of Charge (SOC) increases, the taper.
    Note that the reported charge rate is the average for the session. Your instantaneous charge rate is Volts*Amps/300Wh/mi. In your case the car is reporting 232 mph charge rate, the average since you started the charge session, but the instantaneous charge rate when you took the picture was 390V*120A/300Wh/mi, or 156 mph, still 3x an HPWC with dual chargers... :wink:
