Yah, good point. A pearl on the string up the 395.
I'm going with Lee Vining. It helps to enable Yosemite routes. Mammoth makes little sense to me -- it's more a place for destination chargers.
Great news!It's Alive.
started charging at 11:50 am.
1st I think.
I'm actually jealous that you did this. So many of us here are simply Tesla fanatics. Guilty as charged!I was as lucky to be able to take day off to sneak up here and try it out for fun.
And I believe I can see it west of the blue that has to be Mono Lake - it would appear more to the south of that if it was Mammoth. Of course, we've all learned by now that future SC positions are nominal rather than definite, so until someone finds a permit or someone at Tesla says so, I wouldn't call it conclusive.If you squint, the latitude of that teardrop appears to be a little more northerly than Manteca, so it would have to be Lee Vining.
What a great way to spend a day off! The air there must be clean and crisp! Thanks for the update.Museum manager and a couple of staffers greeted me as soon as I plugged in, so did not record peak charge level.
I glanced in and it was 330 ~ miles of rated charge per hour, so it's full strength.
started with almost full charge (85kwh) in OC this morning, topped off at Barstow, cruised up here (55-65 mph) arrived at lone Pine SC with about 75 rated miles to spare.
Going to check out museum, get lunch and head back.
I'll try pic again.
Thanks for the picture from that spot. From the other side, the Yellow Bollards look wicked close to the driver's door! Glad to see the placement is reasonable.There we go. About noon today.
They are all left, all pull-in spots.Why are there Left and right charge stations in each space? Is that for future dual charge ports or reversing into the space??
Car says "Reduced Service" at Lone Pine, anyone have any insight into this?
@treldib
I just charged there today about 4:00pm on my way to Mammoth. Charging was quick from 40 miles at about 6 miles per minute.
Much better than Inyokern where charging was half the normal rate. Called Tesla and they said it was a problem with my battery being hot. Both stations were about 110 degrees today, so I don't think that was the problem. Tesla warned me I might need 2 hours to charge at Lone Pine, but I got up to 200 mile range in about 30 minutes, starting at 40 miles.
By the way, Inyokern is a hellhole!
