Broadway (Sydney) had this issue, it took a month or two, but then they installed a 4G booster in the space.I've used these superchargers for a couple of quick top ups but haven't seen any charges (dollars... not kWhs!) Are they not charging for use yet?
LTE signal is garbage....
Try buzzing security, at the Broadway Supercharger, the carpark is closed between midnight and 6am, but if you buzz at the boom gate they'll let you in. I think Tesla make it a requirement to have 24/7 access to superchargers.I arrived at 0615 today and it was all locked up. As well I had enough charge to do my trip. Supposed to be open at 0600.
Tesla usually gives a code on your screen when you press on the supercharger to get more info
Newbie SR+ owner here - still waiting for my home charger install so I stopped by at Moonee ponds last night after a drive. It seems that the supercharger connectors won’t plug into the 3 as the connector is slightly different, with the only option being the 16a wall connector off to the side (which would take 3 hours to charge to 80%).
Just wanted to make sure I wasn’t missing anything in terms of using the supercharger - I assume they need some sort of upgrade to the plugs to be used with the M3?
Thanks, it was the CCS2 cable I was struggling with. The middle circular ring on the charger had a different configuration to the input socket on the car, specifically it looked like a circle with a triangle on top whereas the M3 just has a circular connector, hence it wouldn’t plug in.You've tried the wrong cable. The superchargers have 2 cables. 1 is the original MS/MX cable and the other is a CCS2 cable that plugs into the Model 3.
Ah, ok thank you. I was unable to actually ‘free’ the other cable from the supercharger to try it (I realise how lame that sounds just typing it!). Is it supposed to simply unhook / be able to be lifted out of the supercharger like the other one?
PEBCAC, Problem Exists Between Cable And Car?Confirmed this was a me issue not a supercharger issue on a return visit tonight. Thanks Chenkers.
Tested it today, works great. Full bars.The Telstra phone booster should now be active i've been told.
