jbumps
Start and stop continues. We did see the 80KW max our X can take yesterday, but the pack was warm and temps were mild. Still seeing intermittent charging interruption, especially when cold out.
I was there on Saturday. Still activates / deactivates however seemed smoother than my previous visit.Anyone seen any improvement at this SC in the past few days?
I thought that sounded like a throttled 75. I’m also a heavy Supercharger user—57.5K miles in about 2 1/4 years (including 6-7 trips to Morgantown every year from Columbus to watch the ‘Eers). I love my Tesla but honestly probably would never buy another because I feel I’m being penalized for “overusing” something which was the only reason a Tesla for my lifestyle. It makes a significant difference in charging times. I’m really upset about it honestly.
do you guys think this is the physical supercharger or your car and it's BMS system protecting the battery? I just did a long road trip and was seeing variable charge rates. Only once did I actually have an issue with the charge rate.
It was really cold when i drove to Mass. when I plug in i didn't charge that fast at first but give it a few minutes and then it starts ramping up the KW. It's like it knows the pack is ice cold and deliberately starts with a slow charge and as the pack warms up the KW goes up. On the flip side after we were driving all day, it was trying to cool the pack down before charging. Bottom line is I think the SC wants the pack at certain temperature and also what is the current battery charge level before it gives you the KW.
On day two it was only 7 degrees and I was at 80% but wanted 100% before we headed down the highway. I plugged in and only got 3KW. I tried 3 or 4 different stalls before I gave up and just sat there. IT was COLD, I heated up the car as it heated the pack. I slowly came up to 9KW. then to 14KW and finally at 31KW. That is the highest it went after 30 minutes. I gave up within 10 miles of a full charge. But at least I knew the car was warm as well as the pack.
I did see different charge levels at Morgantown when I passed through a couple times, more so than other SC.'s. I now wonder how smart the SC's are vs the car. My level two charger was nothing more than a simple contactor to handshake with my Volt. How do you report a SC as bad? I did have a bad SC in Conn. at the Greenwich Northbound site. It gave you a red LED on the car and kills the car next to it when you plug in. It self resets and starts charging the other stall. I try to call the number on the SC but that is pointless. Is there an email to report it? The guy charging two ports down said he has called on it several times for months with no action. He goes there on a daily basis.
My car is definitely throttled--I asked the local service center, and they confirmed it is. You're correct--the battery temperature plays a huge role in the charge speed, and from my unscientific observations, it seems Tesla has changed that algorithm over the years via updates where the battery temperature seems to play a bigger factor now than when I first got the car.
Was that because you do super charge that much? they did it to protect the battery pack? Not an abuse thing was it? Im running out and will SC today will hope to charge at full rate today. I havent SC for about 2 weeks.
Yes. Yesterday. I used stalls 3b and 4a. I switched only to see if the charging would be different. Both stalls worked well.Anyone else use this SC recently with good experience?
