FlatSix911
Porsche 918 Hybrid
Here you go ... thanks
You do realize that Shoreline/Mountain View is one of the busiest Superchargers in the world.Odd that they should put on so close to the ones at shoreline.
I'm curious where they can find even a parking lot with enough empty space?
Were you paired with another Tesla that was charging?Any thoughts on the slow charge rate at this Supercharger? I was the only car there Sunday at 6:30AM and got a max of 40 Kw at the first stall. I moved to another stall and it went up to 48KW. I was at 45% SOC when I plugged in.
Cold soak. It’s a thing.
If true, then you can drive your car an extra 8 blocks, and it would warm up a bit more, and then charge up faster, often at a net benefit in terms of time and energy used, however, it also increases the probability of mishap while attempting to achieve your net destination. One idea is to go to an errand that is a bit further away first then charge up immediately after driving there, or immediately upon regress back to the SuperCharger area (assuming one problem is that you live too close to the SuperCharger, since that's how it would be cold soaked in the first place). In busy traffic, of course, that is not a good idea, and you might as well just slow charge rather than deal with traffic. That Mountain View SuperCharger neighborhood leaves a lot to be desired, though, so you might try another local SuperCharger area that isn't as crummy. That offers its own suggestion: if there is a SuperCharger a bit further along your pathway (or you could change your pathway to make such a thing true), you can go there instead of the nearest one, allowing your battery to warm up in the process, and then you could charge up with a warmer battery, which is faster, and which would avoid the problem that you're doing unnecessary driving just to increase battery temperature, and you could have a superior layover in addition (win-win-win)! In very cold temperatures, though, this can be too dangerous for SuperChargers that are at a distance approximately at or below the realistic cold-driving range you have left over (and for most summer-bought Teslas, new owners have no idea that this is a tiny fraction of the range available during warmer times), because you might run out of battery on the way, then freeze to death, and let your family inherit a dead (bricked, physically destroyed) Tesla with no warranty nor insurance coverage to boot (lose-lose-lose-lose-lose; Black Swan event); be sure to do your calculations very well in super cold temperatures (if you have any doubt, take the extra time to charge up first and make all sorts of contingency plans that can minimize black swan events (in this discussion related to cold weather), and in any case, learn to do good calculations).Cold soak. It’s a thing.
Slow charge today - pulled into this station, only 4 other cars there. Plugged in any only got 55kW, waited 20 minutes to see if it would get faster, it didn't.
Headed up to the East Palo Alto station since I needed some things at HD - got 75kW there.
K
