Ugh, STILL with the stupid 1A, 1B numbering/pairing system.
When are they going to get a UI/UX consultant to come in and tell them the proper way to interface with PEOPLE.
What's wrong with 1A, 1B? It's better than 1, 2, 3, 4 as you wouldn't be able to determine the pairs?
Maybe I’m just to old, just don’t charge next to someone, problem solved. No need to be able to count.
Looks like it is already at capacity right at opening. They should keep the old 4 chargers or expand this one further.Photo by Naman Bhatia. Only 24 hours after powering up, the Newark Supercharger is busy at the start of a major holiday weekend.
In Woodbridge, the stalls are:
1A, 2A, 3A, 4A, 1B, 2B, 3B, 4B.
If people are in 1A, 3A and 1B, and you go to 3B so you're not next to anyone, you're screwed.
There's absolutely no need to label them as A/B -- that info is superfluous to any regular user. They should just be labeled with BIG numbers on each pair, or as I've suggested many times, color coded pairs ("red pair", "blue pair", etc). So if you see someone on one of the RED stalls, don't go to the other RED stall, etc. The A/B parts just makes it really confusing to people who don't understand it.
Also, when approaching a SC location exactly like in that photo, you CAN NOT SEE THE STALL NUMBERS where cars are already parked! You have to park, and then walk up and down to figure out which stalls are used and which one to best charge on. If they had BIG numbers and/or colors AT THE TOP OF THE STALL, it would be trivial to drive up and quickly determine which stall to pull in to.
Like I've said dozens of times, the 1A, 1B, 2A, 2B system was designed by engineers, not user interface/user experience people. -- AND IT NEEDS TO CHANGE!
Nice find @delanman! If you look at the cam at noon tomorrow, you'll see Simeon Silver and Nautilus Blue there. This trip is dubbed the Delaware Dozen Dash. Going to check out the 12 new Supercharger stalls tomorrow because we can't make it there next weekend.
Check for damage/grafitti too. 10 of 12 spots ICEd.
