But it really could go either way... even if it's listed as "full" or "near full" that info is likely delayed, and/or several cars could finish up an leave before you get there. It's really a crapshoot.
What's really required to make it useful to make a prediction is (a) how many are charging, (b) at what rate, and (c) how many are nearly finished charging or near full SOC%, and (d) no reporting delay. Then and only then can you make a prediction as to what will be available when you get there.
As it is now, it really doesn't give you actionable info.
Unless you're making a decision from only a few minutes away, that still won't be enough - in the time it takes to get there, half a dozen folks on long trips could show up.
The only way the status is going to really be helpful for the folks on long trips that are the main purpose of the system is when it becomes reliably predictive.
I do think that will happen fairly soon. The only thing Tesla can really do with locals is look for patterns in the usage data, but with long trips they can do more.
When I enter a destination that's beyond battery range, 8.0 firmware and later will automatically lay out a sequence of Superchargers to get me there - with estimated arrival times and SoCs, and estimated stop lengths for every stop.
If Tesla had the car pass that information up to a server and assembled it all, they would quickly get a good idea for what future loading from folks driving with Navigation looks like. It might be off by a little here and there, but it should be close.
Once they get confident with that and add some guesses about locals charging, they can start to deconflict it. The obvious way is to send folks running on Nav to less busy sites that overlap busier chains, but they can help even in places where there's only a single viable chain by level loading.
If the system knows that your next stop will be busy, it can set the "enough to reach your destination" notification to show up at a higher charge state where you are now, so you need less time there - conversely, it can get you out of here with just enough to spare and charge up more at the next site if there's a crowd coming.
If a block of folks are traveling close to the same time and route but aren't actually together, charging the later cars higher in the early stops can separate them during the trips without changing arrival times much.
