Supercharger - Newnan GA
Jughead135
206
93
Georgia
@mociaf9 & @MBSinNC
So, you guys are saying even though I had the supercharger set as the destination, and the car decided on its own when to start preconditioning, that it still wasn’t actually preconditioned? How can I control that?
Also: doesn’t charging itself create heat, ie, warm the battery up? In that case, wouldn’t I expect the charge rate to increase initially, until the ideal temp was achieved?
theothertom
377
265
South Carolina
@mociaf9 & @MBSinNC
The car will properly precondition given enough time. If you're only 5-10 miles away from the supercharger, the car might not have enough time to properly precondition.
Yes, charging generates heat but the battery pack is a large mass. It takes time (sometimes a lot of time) to heat up for faster charging. So you will initially see a slow charging rate which gradually increases as the battery heats up.
Edit: Charging rate slows as the battery "fills up" so this complicates the equation.
mociaf9
2,821
5,790
Yes. Preconditioning will help some to achieve a higher charging rate, but in cold or cool weather it usually isn't sufficient on its own to get the battery into a state where it can take the max rate of V3 superchargers. And you can't do anything else to help besides intentionally driving the car hard to generate extra heating. The point is that this is all a modest advantage, not some magic bullet that will guarantee you anything like 250 kW.
Yes, the charging will heat up the battery. And that is a big part of why, unless it's quite warm outside, it's usually the second and subsequent supercharging session/s on a trip where you start to get the max rates. It's because you've heated up the battery and usually been driving at high speeds so it doesn't cool off that much. My intuition is that it doesn't affect the charging curve of the initial session, though. But I may be wrong about that.
Reactions: Jughead135
Jughead135
206
93
Georgia
Agreed with your larger point. In this case, though, I was 30+ miles away, and was driving in excess of 20 minutes at highway speeds before the car started preconditioning. If there's "not enough time" to properly condition, that's one thing--but, in this case, the car didn't even try until 5 or 10 minutes prior to arrival. Curious....
MBSinNC
New Member
Mar 22, 2021
4
9
Raleigh, NC
Just as an update. I used the Newnan location again last night, only driving about 40 miles ahead of time (it preconditioned that whole time). I went from 13% to 90% in 30 minutes with a max speed of 250kW, but the max speed didn't last that long this time. Below is the charging profile the charger gave me this time:
Reactions: Big Earl and byeLT4
Artieg911
New Member
Mar 9, 2020
4
0
Roswell, Ga
Has anyone else noted a slowdown of charging speeds? I charged the first week opened we charged at 225kw. Yesterday it was 120 KW or less. Another owner had the same experience.
Artieg911
New Member
Mar 9, 2020
4
0
Roswell, Ga
Sorry, the attachments are below. Newnan Ga SC
RTPEV
1,012
1,149
Durham, NC
State of charge makes a huge difference. You will only get full power at a very low state of charge. Once you get above 50% it's not uncommon for a taper off to less than 150kW. In my car I see a sharp knee of sorts at about 40% state of charge where the charge rate falls. 109kW at what appears to be just over 50% in your second charge is a tad low, but not too off the mark. On a recent charge of mine I hit 110kW at about 60% state of charge.
Reactions: byeLT4
Hiyoriwoot
7
6
GA
Currently not working. Noticed a few of the newer v3 chargers are randomly down—or half the stalls are unpowered. Not sure what’s going on but this is the second time this week in the metro atl area a supercharger was randomly down for a few hours.
Pluto
is a Planet
Nov 17, 2015
420
707
Auburn, AL
Hmm this is appearing as 11 stalls on the app. I was able to find screenshots of 12 different stall numbers (1A-1D, 2A-2D, 3A-3D) but is Tesla now changing the shown total stalls number based on the whether they're up or down or something?
theothertom
377
265
South Carolina
On the nav (which I assume is the same info as the app) they show the number of stalls that are open. The open ones may or may not be operational. I have a foggy memory that I saw a note on the nav that a charger was not operational, but I don't remember exactly.
