Supercharger only maintaining high amps for short periods, normal?
Discussion in 'Model S: Battery & Charging' started by pixel4, Aug 16, 2016.
  1. pixel4
    pixel4 Member
    SF Bay Area, CA
    Sorry for the long video but if you skip around you'll see my charge bouncing between 80amp and 222amps. Video: Supercharger
    Is this normal? There were no movements in the adjacent stalls. It was frustrating that it didn't stay at 222amps.
    This is at San Mateo / Whole Foods
  2. ShotgunF15E
    ShotgunF15E Member
    San Diego, CA
    No, this is not normal. Next time it happens call Tesla while your car is charging so they can connect and see the issue happening realtime.
  3. Benjamin Brooks
    San Jose, California, United States
    Yes I've seen it before
  4. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Lots of posts about this already, happening at many superchargers in California. Lots of theories as usual but no definite answers. Do let Tesla know when it's happening, the more info they get the better. They will probably tell you to try another stall.
  5. Advicebox
    Advicebox Member
    Berkeley, CA
    #5 Advicebox, Aug 16, 2016
    I spoke with a rep at the San Mateo charger today. He confirmed that Tesla is throttling customers as they get closer to full. The reason is to discourage topping off, and focus on travelers that are bottoming out and need many miles to get to their next destination. I've been to that same supercharger to top off and I got around 150 miles per hour. Today I showed up with only 100 miles left and got up to almost 300 miles per hour. The rep was happy to share how it works.
    • Disagree x 4
  6. NeilErdwien
    NeilErdwien Member
    Manhattan, KS
    Is this something different than the normal taper as the battery fills up? As Telsa explains in:
    Supercharger | Tesla
    Charging each cell is like filling a glass of water without spilling. As the glass fills up, you reduce the flow to catch every last drop. In battery terms, this means reducing current in order to balance cell voltage, ultimately tapering down to a trickle as it nears full. The resulting charge profile is why we recommend charging to 80%, which is typically enough to reach a neighboring Supercharger Station.
  7. Advicebox
    Advicebox Member
    Berkeley, CA
    @NeilErdwien
    Could be. Just passing on the dialogue with the attendant.. but felt like there was some truth or messaging from Tesla to the effect of Throttling.
  8. TexasEV
    Austin, TX
    The attendant doesn't know what he is talking about and as a Tesla owner you should know better than to believe him. He's describing the supercharging taper without understanding it's a property of the battery and nothing to do with "whether you need it or not".
  9. kort677
    kort677 Banned
    florida.
    what nonsense. as the battery reaches capacity it tapers the rate of charge.
    • Like x 4
    • Disagree x 1
  10. pixel4
    pixel4 Member
    SF Bay Area, CA
    I went to San Mateo supercharger again last night to compare. I went from 30% to 82% in about 35-40mins. The amps were stable and slowly eased back as it neared full. I think it was doing around 150amps when I unplugged.
  11. kort677
    kort677 Banned
    florida.
    rypalmer, what exactly is the reason you ticked the dislike switch? was my comment not factual? or there another reason?
  12. ShotgunF15E
    ShotgunF15E Member
    San Diego, CA
    I hope he misspoke and was attempting to explain the normal taper. If they are intentionally throttling charging rates they will only successfully discourage owners from ever purchasing another Tesla....My cell phone carrier attempted this with data rates and I dumped them and switched carriers...
