Mrbrock
Charged here yesterday (Sunday) about 6:00. Site was empty, so were all the spots across next to the building that locals guaranteed would be packed 24/7 when this site address was initially disclosed. Have a couple observations that will hopefully help other MY/3 drivers here (some may have been made before but just wanted to reiterate and expand).
I did not feel the stalls were crowded overall but if you park all the way back, then you will risk hitting your doors on the charge post or bollards. With no curb stops and an actual curb, you are tempted to back all the way up. However, there is more than enough room if you don't back all the way in. The ideal spot is with the back of the rear door being in front of the charge post, you can even go as far forward as having th eback of your rear tire in front of the charge post, there is that much extra room at the front of the stalls for these models. This will also ensure than your front door will be forward of the bollard.
You can see I stopped about a foot in front of the curb and it made getting out a bit tricky with the front door not clear of the bollard. We didn't have anyone getting out of the back so that wasn't affected but there is clearly room to be 1-2 ft farther forward than I was and still be within the stall at the front end. it would be nice if they put a stop even with the front of the charge posts but I guess this gives more room for alternate makes to use the stalls when the adapters are available, although opening doors would be tricky for those will front ports (F150).
