Thanks. So the V3 chargers will not drop wattage when adjacent charger is being used?
The short answer: most of the time, that's true.
The long answer: As far as I understand, the v3 charging cabinets are interconnected via a DC bus, so they can share power with each other. If everyone showed up with low state-of-charge and plugged into all the stalls at the same time, I think you'd only get about 80-90kW per stall (assuming no power packs connected to the system).
But in reality, that rarely happens. Most of the time, there's enough spare capacity to maintain a reasonably high charge rate for all the stalls in use. Someone please correct me if I'm mistaken; I'm not an expert.
