Just completed a 600 mile trip from FL to NC. There are now 10 Tesla Superchargers along our I75/I85 route. When I plug in our destination, the nav system selects SCs that I don't want to use: First stop at the limit of range that would require slowing down to reach. Second stop in downtown Macon, GA that takes longer to get to and is further away from food/shopping options. The only solution I have found is to navigate to the SC desired. On the first stop I plugged in our 2nd SC stop before we got there. Initial charge rate was 130KW and very fast. We charged in less than 30 min., faster than expected. Upon arriving at 2nd SC, the initial charge rate was 75KW but we were going shopping so I assumed it would increase. Upon checking 15 min. later I was appalled to see that it was down to 25KW! I went back to the car and moved it to a new charger even though there were only two other cars charging and none nearby. The next charge cycle stayed at 75KW until we were done. The charge time took about 25 min. longer than anticipated so I was very disappointed. 3rd stop, same problem. We were at about 12% SOC but only charging at 75KW. I unplugged and plugged back in, no change. On a hunch I realized that the Nav system had no final destination plugged in. I manually stopped charging and entered our destination into Nav, about 100 miles away. Charger rate when immediately to 145 KW!!! We were done charging in about 12 min.
So, clearly Tesla has determined that if you are at a SC with no destination entered, you are not in a hurry so they limit your charge rate to 75KW. I am not sure how it dropped down to 25KW, but perhaps after some period of time it drops that low. This would help discourage local owners from using SCs instead of charging at home or with destination chargers overnight. It probably also helps prolong battery life. So I understand all of this but I was totally frustrated that I had to figure this out on my own and suffered about 40 min. of extra charge time which makes a lot of difference on a 9 1/2 hour trip. I wish Tesla would be more transparent with these things. They also need to add features to Nav to allow selection of specific SCs (unless this is already possible and I just don't know how to do it!
Bottom line: Always have a beyond destination programmed into Nav when charging at a SC!
My car: Model 3 LR AWD w/Aero
