nlc: I believe you have reversed the connections from your receive interface to the AVR-CAN on pins EXT2-6 and ext2-20.
Oupss !! You are right, here is the good wiring :
I have a question about the code used in your setup:
- How much time does the Model S receive the 5% 1KHz Pilot before it goes into digital signalling mode?
Do you send a burst of 5% then just wait, or what?
- How does the car indicate the state change to digital?
I don't measured exactly, but it's very fast :
When connecting to the car, the EVSE is in state A, and the car ask for state B. The EVSE sends the 5% PWM, and very quickly the car switches to state C, to tell the EVSE to switch to CAN digital communication. At this step your EVSE must set the CP line to -12V continuous. You have approx 1s to detect the car switched to state C and set -12V on CP line before it sends the first CAN frame.
Yes, that's this schematic :- What is the circuit that you use in your CAN-enabled EVSE that sends the CAN ACK bit? (Is this the additional circuit you published earlier?)
Surrounded parts are components I added for the CAN interface. In my case the microcontroller of my EVSE box doesn't support CAN, thus I used another board, but that's the same schematic, CAN_TX and CAN_RX just go on another board in my case (with common GND of course).
I'd like to try to duplicate your results before I move on to connecting to a SuperCharger.
You are right that's a good idea !
