Supercharger Question
Discussion in 'Model S: Battery & Charging' started by Mr X, Apr 25, 2015.
  1. Mr X
    Mr X Future Martian
    Simi Valley, CA
    I was at the Oxnard Supercharger today watching Tesla's go in and out and saw a new P85D pull in. The guy plugged in, got out and waited for about 12 minutes and then unplugged and left.
    Was just curious how many miles did he get for only being plugged in for literally 12 minutes? :confused:
  2. Stoneymonster
    Stoneymonster Active Member
    Aptos, Ca
    Maybe it was new and he was just trying it out. I did that once.
  3. shadowinstallz
    NYC, United States
    Depending on the SOC prolly got about 50-75 miles or just enough to get to the next supercharger......or just trying it out also.
  4. paulkva
    paulkva Member
    Falls Church, VA
    I've made supercharger stops like that before. If, for example, I start my day with a full battery (or close to it) and drive 130-150 miles to a supercharger, and if the next supercharger is also 130-150 miles away, then I might stop just long enough to stretch my legs and pick up enough range to arrive at stop #2 safely. Then stop #2 becomes longer (e.g. lunch or dinner).
    It goes against the common advice on these forums to "ride the bottom of the battery" (recommended because you'll gain range more quickly when the battery is low), but it generally worked well for my family on our long trip up & down I-95 last summer.
  5. vvanders
    vvanders Member
    Portland, Or
    Yup, a ~10 minute stop from exit/exit is usually enough for me to make it home for the last stretch from the closest supercharger. 120kW at low SoC is an incredible thing.
  6. TTT
    TTT Member
    San Diego
    I've had to stop for biological breaks and have told my passengers we'd have to stop at superchargers. Those breaks were 10-20 minutes and if I was going to stop didn't want the idle time to go to waste.
  7. shadowinstallz
    NYC, United States
    Yup.
  8. Khatsalano
    Khatsalano Member
    San Mateo, CA
    I've stopped for 15 minutes or less regularly. I do this as a combined road trip bathrooom/stretch break and to pick up some charge to reduce charge time at the next stop. At 360+mph, I've picked it 75 miles of charge or more easily in that time. I drive a lot for work and I find taking a 15 minute break every 90-120 minutes is a good safety habit to stay attentive while driving. Coincidentally, this is also the typical distance between SCs.
  9. jbcarioca
    jbcarioca Well-Known Member
    I have not had my car long enough to make any habits, but this one makes sense to me. Stopping at most superchargers along the way does make the equivalent of the bio breaks I typically use on long trips anyway, every 1 1/2 hours or so for ten-fifteen minutes to walk a bit and freshen my energy level. Good idea to use superchargers for that.
  10. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    My wife does this regularly. Her commute once a week to Oakland or Vallejo is just a tad more than a full charge at home will provide. So she stops either in Fremont on the way there or Gilroy on the way back for about 15 -20 minutes. Gets her home with just a few miles left and we just charge overnight for her regular commute to San Jose. She could use Gilroy every couple of days for her normal commute for free electricity, but home charging is the best, being both convenient and cheap.
    Hopefully, her business will provide a source soon so that the quick SC stop can be eliminated.
  11. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    Even with my slower charging 60kWh pack, I've done the same. If I was really low and just needed enough to get home, 5-10 minutes would do it :) that would net me about 50-70 miles. Hopefully, i had a bit of range to begin with, so add that to whatever I had, and I'm Jucin.
