After they mentioned the trickle charge I stayed put where I was. It trickled at 1kW for 10 minutes or so then jumped up to 112kW on its own and started supercharging as normal. After about 3 minutes at that rate it started dropping fast. That’s when I started moving stalls. According to Teslafi I went from 0-8% at the first stall. The second one started at 115kW and stayed there for a few minutes before starting to drop quickly. (Teslafi says 8-20% for this stall).
The third stall got me from 20-90% with a normal charge rate, starting at 115kW and tapering down normally as the car has every other time I’ve supercharged.
/edit. I should add Teslafi reported my voltage was 290-ish at the beginning when I was trickling. The supercharging “proper” kicked in when the pack went above 300v.
