ggumz
Each stall is numbered on the bottom of the pedestal.
I'll definitely pay more attention next time, didn't even notice that.
As a new owner, I think it's also worth asking if you are aware that when entering a paired stall already occupied (say 1A is occupied and you pull into 1B), you are going to have a lower charge rate until their car reaches a certain capacity. Also, if your car is dramatically low on charge, the charge rate you draw under, say, 20%, would be much lower than if you pulled in and charged when you were at 60%.
Admittedly I was not aware of that, but it totally makes sense, thanks!
Is such severe fluctuation normal? Throughout the duration of my charge, it kept rising and falling between 30-80kwh. For reference, I started charging with 39% battery and disconnected at 81%.
