Supercharger - Selma, TX
Discussion in 'Texas Supercharger locations' started by brkaus, Aug 4, 2018.
  1. brkaus
    brkaus Well-Known Member
    Austin, TX
    This was noticed by @Bruce W in a different thread.
    Creating in the Texas supercharger specific area.
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    This may be the HEB in Schertz that had a utility survey for Tesla recently.
  3. brkaus
    Austin, TX
    True. Could be anywhere (if it even happens). Figured the city name Tesla used might be the best start.
  4. TexasRat
    TexasRat Member
    Austin, TX
    Really hoping that this opens before November so that I can use it when I take the family to six flags. If not, I need to figure out another plan, maybe using the SC in san marcos, though that's terribly inefficient coming from Austin.
  5. BerTX
    BerTX Supporting Member
    Texas/Washington
    Make other plans. No way this will be open by November.
    Can you explain how San Marcos is "inefficient"? Because it is too close to Austin? Drive to Fiesta Texas (BTW, if you ask for directions in SA to Six Flags You will end up in Dallas -- it's Fiesta Texas) and stop off in San Marcos on the way back.
  6. Xd85
    Xd85 Member
    Central Ohio
    Plan to do the same thing. If you drive really efficiently a 75D can do it without supercharging, but why miss out on the fun? :D
  7. TexasRat
    TexasRat Member
    Austin, TX
    @BerTX I’m driving from north Austin down to Fiesta Texas. I will have a pretty high SOC by the time I hit San Marcos on the way there. (The inefficiency that I was referring to was charging on the way there, since it’ll be a slow charge.)Then I’m going to park the car all day at the park and then start my drive back. I haven’t done a long trip on the car yet, so I’m a little uneasy of seeing where my SOC is at by the time I hit San Marcos on the way back from Fiesta Texas. I was worried I might not be able to make it all the way back. That’s mainly my ignorance in an X 75D. I haven’t done enough long range driving to get an idea of how far I can go!
  8. Xd85
    Xd85 Member
    Central Ohio
    or just don't start with a full charge? enough to make it to san marcos with 20-40% SOC would be better on paper. Bear in mind they only have 5 stalls, and last I checked perhaps not all of them reach 100+ kW.
    • Disagree x 3
  9. BerTX
    Texas/Washington
    That isn't a very long trip. Take a few highway trips before then if it will make you feel more comfortable. Leaving from Round Rock, going to the Park, then going to San Marcos should have you arriving with 30% or more SOC -- it's only 150 miles. November can be cooler and you may encounter wind at any time, but that is still a VERY comfortable margin. It should be a good trip to build your experience level and confidence. Use your Energy screen on the main screen, set your destination, and select the "Trip" tab on the Energy screen. It will tell you your level of charge upon arrival IF you continue to drive as you have been driving. If it dips to an uncomfortable level, then slow down and it will come back to a good buffer. It'a amazing how much a fairly small decrease in speed will affect your range.
    This trip is more complicated than some, since it has a waypoint in the middle, meaning the in-car Nav can't accurately estimate your SOC upon arriving back at San Marcos on the return leg. This is where the auxiliary routing apps will help you. There are several, the simplest and cheapest being EVTripplanner.com. You can play around with that, but be very careful because it's estimate of range for the MS75D is overly optimistic.
  10. Xd85
    Xd85 Member
    Central Ohio
    @TexasRat Everything @BerTX said. I've driven to Dallas a few times in my MS 75D and have similar quandaries since Italy SC is placed similarly to San Marcos in your situation. Tho OP has Model X, so perhaps that's why the margins are smaller :)
  11. TexasRat
    TexasRat Member
    Austin, TX
    Thanks for all of that info! Sound like I need to make a few trips and see how things go
  12. TexasEV
    Austin, TX
    I drove from Northwest Hills to the area near Fiesta Texas, and back home with a stop at San Marcos on the way home in my S60, so that should be similar to an X75. Start with a 100% charge. If you're getting nervous about charge on the way from Fiesta Texas to San Marcos, slow down by 5 mph.
  13. DriverOne
    DriverOne Supporting Member
    Austin, TX
    Not really. Let's say you need to charge in San Marcos to 80% before leaving. Would you rather start that charge at 30% or 70%?
  14. Xd85
    Xd85 Member
    Central Ohio
    My bad. Got focused on OPs concern of inefficient charging a high SOC. Agree always start a trip with 100% at home to avoid impact of surprises (wind,rain, elevation effect, etc)
  15. SpiceWare
    SpiceWare Member
    Fresno, Texas
    Hmm, with the discovery of the Richmond Supercharger, there will be 2 in the Houston area located at Rudy's BBQ. There's a Rudy's in Selma, might be worth keeping an eye on it.
  16. PLUS EV
    PLUS EV Running on Empty
    Seattle
    The El Paso supercharger is also at a Rudy's. I recommend the moist brisket.
  17. animorph
    animorph Active Member
    Scottsdale, AZ
    I had the lean brisket at the Rudy's at the El Paso Supercharger. I'd recommend the moist as well.
  18. SpiceWare
    SpiceWare Member
    Fresno, Texas
    Had the moist for dinner last night! After helping with Houston deliveries yesterday I stopped by a friend's & showed off Talith to his dad (he was quite impressed). Afterward we went to Rudy's and I topped off Talith at the 290 Supercharger while we ate at Rudy's.
  19. bodhipooh
    bodhipooh Member
    Jersey City, NJ
    Reviving this old thread to ask if anyone has an update on the future location of this Supercharger, and its current construction update. The Tesla site is still only saying Coming Soon and expected by 2019.
  20. mociaf9
    mociaf9 Active Member
    Instead of starting a new thread, I figure we can just continue to use this one.
    Confirmation (via TABS) that the "Selma" supercharger will be at the Schertz HEB and is potentially planned for construction to start this calendar year: TDLR TABS - Project Details
    • Scope of Work: Telsa is proposing to install (8) electric vehicle charging stations within the existing parking lot of the shopping center.
    GPS (guess): 29.598106, -98.278764
    Don't pay too much attention to the proposed start date in September shown on the original document. Read that as an optimistic target that's likely to be missed. These records are generally created before a building permit is applied for and that date assumes a brisk approval process and that Tesla keeps this on the front burner. So, any delays beyond a straight rubber stamping in getting their permits approved will push that back. But there's a decent chance it'll break ground within a few months of that date (i.e. this calendar year).
    @BlueShift @Chuq @MarcoRP
    • Helpful x 2
    • Informative x 2
