David99
Thanks Toni for posting this data! Very useful.
To get a better idea how much faster the Model 3 charges:
my 'old' Model S 85 needs 50 minutes to charge 190 miles (best case scenario)
the Model 3 needs 24 minutes to do the same.
Both cars max out at 116 kW power at the Supercharger. It just shows how little the maximum charge rate means. The Model 3 maintains a higher rate much longer (to a higher battery level). It also needs less energy to drive the same distance. Both combined add up to pretty much double the charge speed or half the time spent at each Supercharger. That's a huge improvement.
Try Teslafi.com! I've been using it for more than 2 years. Captures and logs everything the car sends out to the mothership. When you sign up, you can use 'sharkcookie' as a code to get an extended free trial period.
i don't suppose there's any plan to port this to android or a web app?
