Supercharger - Turlock, CA (permit found, May 2020)
Discussion in 'California Supercharger locations' started by tij664, Jan 16, 2020.
  1. tij664
    tij664 Member
    Turlock, CA
    I noticed at the beginning of 2020 this popped up as coming soon. There are two electric utilities serving Modesto and I know the person at one of the two utilities who receives these requests. In early 2019 this person told me that Tesla had approached his utility requesting service for a supercharger location at the Target location in Turlock, CA. This in the vicinity of Modesto. The utility informed Tesla that an easement was needed to start utility construction (transformers, lines, etc.) since Tesla does not own the property. They balked at having to do that and pretty much left the request pending and according to my contact, they haven’t been contacted since. Presumably they may be negotiating an easement with Target or the property owner or attempting to obtain city permits. Or they could just have moved on and started to look at other locations in this area.
    Looking forward to this along with a couple of other proposed locations since the Hwy 99 corridor is severely underserved with Tesla Superchargers at the moment.
    • Informative x 2
  2. tij664
    tij664 Member
    Turlock, CA
    Ok. Upon further research, the City of Turlock permit system shows:
    Permit #2018-00001168
    Description of Work: TESLA CHARGING STATIONS
    Permit Status: Permit Created
    Total Valuation: $150,000.00
    Not sure if the title of this thread needs editing or how to do it.
  3. Tam
    Tam Well-Known Member
    Visalia, CA
    Thanks for the research!
    The search engine is at:
    https://www.cityofturlock.org/buildinginturlock/buildingsafety/buildingpermits/researchpermits.asp
    Then you need to enter the address number: 3000
    Then the street name: Countryside DR
    Then you would see:
    @BlueShift for sc.info:
    Supercharger--Turlock, CA
    Target
    3000 Countryside Dr, Turlock, CA 95380
    Status: Permit
    Stalls: unknown
    Power: unknown (with $150,000 price tag, it could be 72 kW Urban Supercharger)
    • Informative x 2
  4. bmah
    bmah Moderator, Model S/X, California Forums
    Lafayette, CA, USA
    Moderator note: Thread title updated to reflect latest research.
    Nice work tracking this down, folks!
    Bruce.
  5. cpa
    cpa Active Member
    Central Valley
    I would hope that these would be regular V2 or V3 Superchargers. I don't think that there are that many residents of Turlock who own Teslas and would need to charge locally. Highway 99 is sorely lacking in charging options for long distance travel. Turlock north has ample coverage, but south only has Fresno until the Visalia and the other planned sites are operational.
    If Tesla were smart, Turlock would have at least 14 stalls, if not more. The ten currently in Fresno are nearly full seven days a week from late morning until mid-afternoon (albeit locals are part of the problem.)
  6. ucmndd
    ucmndd Well-Known Member
    Interesting. I wonder if this actually the Modesto or Merced “coming soon” pin.
  7. Tam
    Visalia, CA
    Turlock is 26 miles from Merced and only 14 miles from Modesto.
  8. Pluto
    Pluto is a Planet
    Stockton, CA
    If the latest status update was that the permit was created all the way back in 2018, then it's probably no longer valid... Usually these expire after a year. Still a nice find and I would keep an eye/ear out for other permits in Turlock!
  9. tij664
    tij664 Member
    Turlock, CA
    It’s possible they do expire after a period of time although the city’s system seems to distinguish between different permit status: i.e. issued, created, canceled, completed, etc.
    Also it looks like they have another permit set up which shows 18-25 charging stations installations (destination chargers too?). Wondering if that’s just a duplicate..
  10. KathyApplebaum
    A total valuation of $50K doesn't match with 18-25 charging stations. I doubt 18-25 describes the number of stations. (Especially because "station" is singular)
  11. golfpilot
    golfpilot Member
    Modesto, CA
    The target parking lot is not a good place for a traveling charger. It takes a solid 5 minutes to get there from the freeway and that parking lot fills up often. 72kw Chargers would be good there though.
  12. mociaf9
    mociaf9 Active Member
    The "18-25" is almost certainly a file number being referenced, not the number of charging stalls/stations. It's probably related to the planning/zoning process (maybe a planning application number?). I would interpret it as file/application #25 from 2018.
  13. socketrocket
    socketrocket Member
    This shopping center would be towards the top of my list on places for an extended stop if I was traveling through. Lots of walk-able food options and easy to get to. I mapped the travel from the furthest ramp (southbound) to the area I think they'd stick the chargers, and it's 3 min from the freeway. The lot only becomes an issue around the holidays, but even then, the edges of the lot (where the chargers would likely go) don't get used.
    At any rate, I'm betting the newer pin in Modesto means they're moving forward there. Turlock has cheaper power though....
  14. shs1
    shs1 Member
    Mariposa CA
    It is strange that there is no "coming soon" pin on the Tesla Find Us map for the Turlock or the 2nd Manteca Supercharger, and yet there are pins for other nascent chargers were no permits or locations exist.
  15. Carlog
    Carlog Member
    Did some research and found out that Tesla did the application, but never pulled the permit so it expired after 1 year. I looked up the person's name on the permit and according to their LinkedIn profile, they don't work for Tesla anymore.
    • Helpful x 2
  16. tij664
    tij664 Member
    Turlock, CA
    My contact at the local utility serving this location (TID) says this is still happening. Tesla is going full speed ahead with the build here and there has been plenty of back and forth communications between TID and Tesla within the last couple of weeks to prepare to break ground. He says they will have both superchargers and level 2s here.
  17. Carlog
    Carlog Member
    Awesome! Is it still at the same address?
  18. tij664
    tij664 Member
    Turlock, CA
    Yes. It is the same spot which is at the end of the Target parking lot right next to El Pollo Loco.
  19. Carlog
    Carlog Member
    Sounds good. I wonder why the City doesn't have any updates on the permit.
  20. jaspal
    jaspal Member
    Turlock, CA
    Looks like the permit is cancelled now, yet there is another permit still pending (pic belwo). I also contacted TID and this is what they had to say (pic below)
