Supercharger - Whangarei
Discussion in 'New Zealand' started by khayyam, Sep 25, 2019.
  1. khayyam
    khayyam Member
    Auckland
    Does anyone know about any progress or the likely opening of the whangarei supercharger? Says "Target opening in 2019" which I interpret as sometime between tomorrow and never.
  2. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    Moderators Note.
    I have created this Thread for the Whangarei Supercharger as there is a recent enquiry about it. See above.
    Having seperate Threads for each Supercharger makes it easier for people to find the latest information about them and any other outages or relavant events.
    I will make any Proposed Supercharger Threads 'Sticky" until they have been open for a few weeks.
    I invite anyone to create a similar thread for the other upcoming or open Superchargers like Tauranga.
  3. khayyam
    khayyam Member
    Auckland
    For those who are thinking that the chargenet alexander st location will fill the gap while waiting for the supercharger, be aware that the gate is closed on weekends and getting access isn't particularly easy. (Plugshare comments suggest that you can call to get access, but after trying that for 5 minutes we decided it was easier to drive on to the next charger).
  4. khayyam
    khayyam Member
    Auckland
    Now "target opening 2020". Unsurprising I guess.
  5. Ecoli
    Ecoli Member
    New Zealand
    Yeh abit disappointing, but I guess to be expected
  6. Chuq
    Chuq Active Member
    Hobart, Tasmania, Australia
  7. khayyam
    khayyam Member
    Auckland
    Hooray. Yes I saw somewhere that it was going to be in Forum North, and iirc that they had found asbetos there and that held everything up...
  8. Ecoli
    Ecoli Member
    New Zealand
    That's good news
    Hopefully it's free parking
  9. telsanzjohn
    telsanzjohn Member
    Auckland
    Word is this site is now on target for completion by early December
  10. Ecoli
    Ecoli Member
    New Zealand
    Fingers x'd, it's been a long time coming
  11. khayyam
    khayyam Member
    Auckland
    Going north in Jan. I hope it's true. But I also hoped it would be live for our trip north in Jan of this year!
  12. khayyam
    khayyam Member
    Auckland
    Pics on the FB group. Supposedly weeks away. Just in time for the summer trips if so!
  13. Matt_NZ
    Matt_NZ Member
    New Zealand
    Yep, here's todays pic update courtesy of the Facebook group. As you can see, they're pull in stalls which may make them more towing friendly depending on the room to the left of the photo.
    • Informative x 2
  14. Ecoli
    Ecoli Member
    New Zealand
    Looking good
    Thanks for the update
    Does anyone know what KW they are
  15. totoro722
    totoro722 Supporting Member
    Coastal Orange County CA
    Very curious. What are the two separate charging cables per station for?
  16. Matt_NZ
    Matt_NZ Member
    New Zealand
    They will be the standard 120kW Superchargers. No V3 yet - V3 is identifiable with only having the CCS cable.
    The top one is the "legacy" Type 2 only cable for the Model S/X and the bottom one is the CCS2 cable for Model 3/Y. Tesla uses the same charging connectors in New Zealand as Europe.
  17. Stromi
    Stromi Model 3 SR+
    Awstralia
    Both cables are exclusively for supercharging Teslas.
    The lower cable has a 'Tesla' plug for the Model S and Model X.
    The upper cable has a CCS2 plug for the Model 3 (in non-US markets).
    History of Tesla Supercharging is the Model S and X have a 'Tesla' charge port that is a modified IEC Type 2 port
    that accepts DC high voltage on the outer pins.
    The Model 3 was designed for the later European DC fast charging standard CCS2 (that is non North America markets).
    Tesla modified the SC units to charge both Model S/X and Model 3/Y.
    Last week I assisted a new Model 3 owner using the Ballarat SC for the first time who selected the 'Tesla' plug (wrong) which actually fits the Model 3's IEC Type 2 port.
    Once I sorted him out to use the top cable with the beefier connector, he was OK to charge.
  18. totoro722
    Thanks for the explanations.
  19. khayyam
    khayyam Member
    Auckland
    It is a bit confusing. Had the same problem at first too.
  20. khayyam
    khayyam Member
    Auckland
    Apparently it's live. Hooray.
